replacement OEM battery need suggestion
could anyone give me some advise replacing my OEM battery? I am currently living in Hawaii and it seem like no one carry any aftermarket replacement battery for our GE8. I use my car daily driver.
Did you try your NAPA Store? The Part # is 65151R. The specs are below:
Attributes Battery BCI # : BCI #151R
Battery Height : 8 3/4"
Battery Length : 7 1/4"
Battery Voltage : 12 Volt
Battery Width : 4 15/16"
Battery Cold Cranking Amps @ 0 Degrees F : 330
Battery Cranking Amps @ 32 Degrees F : 440
Battery Posts Type : Top Post
Battery Reserve Capacity (Minutes) : 55
Battery Weight : 19 lbs
Jensen Healy
12-06-2019 02:54 PM
revd34
07-30-2009 06:43 PM
SSM0423
03-04-2008 08:13 AM
piclistguy@yahoo.com
05-04-2005 11:16 AM
