How do I enter the Radio Code to unlock the radio?
I have the code. It has a numeral 9 and 0 in it. I can't figure out how to enter it.
Which buttons do I use? Maybe it's not the code? It has a letter and 3 digits. How do I enter it? Thanks. |
There should be only numbers. 5-6 I believe. Numbers only 1-6 is available for the code. A 9, 0, letter is wrong. Check your owner's manuel. The code is in there. Be careful, only 10 tries.
Example: If your code is 265341, you would hit it exactly as you see on your satellite radio numbers. It unlocks on the last number.
Honda should have gave you a 5 or 6 digit code I believe. If you don't have it then you would have to see your local honda dealership.
Where exactly is it in the manual??
The code will not have a 9 in it. Thats the serial number. If you dont have the 5 digit number which is the code (and has only numerals 0-6 in it), you have the 8 digit number which has numerals 0-9.....you have to call the dealer or pm me and I can give you the radio code.
I have to replace batterry. Will Radio work afterwards. I purchased my Honda with 25,000 miles from a honda dealer. I wasn't given a code. I recall when owning another Honda. I was in need of a code. They wanted to charge me for it back then.
Originally Posted by MiamiJazz
(Post 1165894)
Text me with your serial number, I will get you a radio code. 252 342 3562. |
For those in the future with the problem, my radio code was on a plasticized business-card tucked in the vinyl blue pouch with the owners manual inside of it. If they're all issued in the same way and you haven't lost anything, thats what you may be looking for.
My radio code is inside my glovebox?
Plus out of some random stupid luck, my radio code is also my zipcode. |
Originally Posted by Katsumoto
(Post 1168955)
Radio code
Originally Posted by bonylad
(Post 1165928)
you a radio code. 252 342 3562. Hiya i urgently need radio code of the serial number ABT 25014978 of honda jazz 2010 |
Looking for radio code?
Looks like about 4 digits?
Vin#JHMGE8H51CC008107 |
