cranking in the morning ?
Old Jun 11, 2013 | 11:17 AM
linnboi's Avatar
i feel it takes longer / more cranks to start the engine when cold ?
anyone have some idea of why ?
thanks
Old Jun 11, 2013 | 01:17 PM
blaaaackfit's Avatar
That is because your battery is going bad, how old is the battery. Maybe you should get a battery with more cold cranking amps
Old Jun 11, 2013 | 04:27 PM
alexcrouse's Avatar
Its because its a modern high efficiency engine. It minimizes wasted fuel during startup by not dumping tons in, like normal cars do. It bugs me too, but my lexus would spray fuel out the exhaust when cold started, even new! (also EFI, but vintage 1992)
Old Jun 11, 2013 | 05:03 PM
SieGunso's Avatar
In in the same boat. Heard theories from different seasonal blend of fuel to bad sparks or like the above stated, bad battery. I just learned to deal with since it only happens when I haven't driven it in a few days.
Old Jun 12, 2013 | 08:35 PM
DrewE's Avatar
I'd say it's because the engine is cold, and it takes a tiny bit longer to start up when it's cold. If it's really, really cold, it takes even longer to start up.
Old Jun 13, 2013 | 01:17 AM
loudbang's Avatar
Because colder fuel takes longer to atomize making it harder to ignite in the combustion chamber.
Fweemn
Jan 20, 2020 10:28 AM
Dwalbert320
Nov 15, 2015 09:42 AM
Benjamin Davies
Dec 9, 2014 03:50 PM
Benjamin Davies
Nov 19, 2014 07:07 AM
Benjamin Davies
Nov 18, 2014 09:53 AM
