Fit 2008 Struts
I started removing the left front strut, I have everything but the top off but I don't understand how it comes apart. The strut bolt coming through the spring tower has a hex slot and a 17mm nut. Is it safe to remove that nut? or will the spring decompress?
Good advice will be appreciated and followed. Thanks a Lot |
The spring is under tension so a spring compressor should be used to prevent it from de compressing.
According to this DIY there is not a lot of tension so you don't need a compressor. https://www.fitfreak.net/forums/fit-...-08-gd3-8.html |
