My 2012 is a brick
Old Nov 17, 2015 | 11:16 AM
Almost_useless's Avatar
Unhappy My 2012 is a brick
Hi everyone,
I've been coming here since 2010 when I got my first Honda for information but this is my first time posting. My 2012 Honda has been driving fine.. forever. I've never had a problem with it. But last night I went to Chipotle, parked my car, and came back out after 5ish minutes. When I put the key in the ignition... nothing. No clicks, no lights, no electric locks or windows. The brakes also won't depress. SO I'm assuming it's either the main relay or ignition switch? I'm borrowing a power probe tonight to try to get a little more information. Any other thoughts?
Thanks so much!
Summer
Old Nov 17, 2015 | 12:12 PM
bigbacon's Avatar
Originally Posted by Almost_useless
Hi everyone,
Thanks so much!
Summer
the battery? start easy and try another battery first.
Old Nov 17, 2015 | 12:33 PM
cajlog's Avatar
Sounds like your battery, check if one of the poles became loose.
Old Nov 17, 2015 | 03:34 PM
yah, as others stated, check your battery and the terminals.
Old Nov 18, 2015 | 02:25 AM
Fitsme5312's Avatar
Is your car a manual? Maybe you can try to roll-start it in a safe environment.
Do you use keyless remote entry? Did those power locks unlock? If it's totally dead, it sounds like a battery terminal or fuse...nothing too serious.
Old Nov 18, 2015 | 09:44 AM
DrewE's Avatar
Like the others said, it sure sounds like a battery connection or the battery itself. I would tend to guess a bad connection since it came up suddenly. Possibly the ground connection corroded or rusted loose.
The brakes are always much harder to push without the vacuum assist, which comes when the engine is running. (There is a little vacuum accumulator tank to give a couple of stops if it stalls). However, with some muscle, they will still work. I think you (and many other people) would find it instructive sometime to go to a safe open area, shut down the engine, and see how the steering and braking feels without power assist so you have some idea what to expect should something unexpected come up.
Old Nov 19, 2015 | 12:27 PM
So it's not the battery. I had it tested and it's fine. I got a probe out and the alternator is fine as well. I have power and probe all the way up to the alternator but no charge AT ALL throughout the entire interior fuse box. So, somewhere between the alternator and the fuse box I'm losing power.
Old Nov 19, 2015 | 06:00 PM
Fitsme5312's Avatar
Maybe a bad wiring harness or a loose connection somewhere? Have you checked all of the fuses? Can you get your car running at all? What is the battery voltage while the engine is running?
Old Nov 19, 2015 | 06:07 PM
xxryu139xx's Avatar
check the big fuses under that red cover on the battery
Old Nov 22, 2015 | 01:01 PM
Mister Coffee's Avatar
^^Yeah, I was thinking some sort of main fuse issue (though I don't even know how our cars are set up for fuses).
EDIT: https://www.fitfreak.net/forums/2nd-...ml#post1326857 There's a Charging System wiring diagram. I wasn't able to drop in the link to the specific page in the manual.
Old Jan 2, 2016 | 11:45 PM
"ItWontFit"OhYesItWill's Avatar
? AU what's the word
shutterbughannah
Sep 27, 2016 09:55 PM
rcbanni
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 31, 2014 11:00 PM
john21031
Feb 13, 2013 04:29 AM
Scala
Jan 10, 2012 05:46 PM
JDMxGE8
Aug 19, 2011 02:39 AM
