Wiring Aux Device Behind Dash?
Old Sep 20, 2016 | 11:39 AM
Corbet's Avatar
I'm looking to add bluetooth functionality to my Base 2012 Honda Fit using an external Bluetooth device that is powered through a car charger and connected to the vehicle with an AUX cable.
Would it somehow be possible to wire up the AUX cable behind the dash instead of just plugging the AUX cable into the front AUX port? I want this installation to be as clean as possible.
Old Sep 21, 2016 | 04:23 PM
Black3sr's Avatar
Yes you can. Pull panels off to get at it. I wired my heated seat pads in there to the Aux and put the switches in the lower panel.
Old Sep 22, 2016 | 06:51 AM
Rob22315's Avatar
I ended up going back to the cheaper unit with two plugs - one for the headphone jack and one for the Lightning connector. The Lightning connector on the more expensive unit wouldn't seat properly and kept disconnecting so it's now sitting on a shelf.
Wpaxton1
Mar 21, 2018 06:01 AM
BurntZ
May 17, 2013 09:23 AM
cruzitude
Oct 31, 2008 01:24 AM
FrogDaddy
Apr 24, 2008 10:30 PM
Navin323i
Mar 19, 2008 08:56 AM
