Help with the independent fog light mod. Ge8
So I wanted to do the independent foglight mod since getting led fogs so they work correctly...
The videos and pictures I've seen from the connections inside the steering wheel cover don't seem to ever be for a ge8. The connectors are not the same, but will the cables be of the same purpose as the older model? I can't find a wiring diagram to the connectors within the steering wheel as I'm not necessarily sure what they are even called. Any help would be appreciated Thanks again https://www.fitfreak.net/forums/2nd-...t-mod-ge8.html previously posted |
