uRabbit's 2009 CBP Fit "Build" Thread
Old Jun 20, 2025 | 10:10 AM
  #41
uRabbit's Avatar
Alrighty! Did a few more things with Betty.
New Struts
Installed new KYB Strut-Plus up front and struts in the rear. I torqued them to factory specs, which are 33 fit-lbs for the top and 47 ft-lbs for the lower, which didn't feel tight enough to me. A few days later, and sure enough, they loosened themselves up. I then torqued them to 80 ft-lbs and they're great.
Had some trouble with the first front one I did. The CV axle kept popping out of the transaxle (I might have terminology wrong; I'm no true mechanic). I had to wait till my wife got home to have her jiggle the opposite side while I pushed in.
It would have taken only 5 hours to do all 4. Would be even shorter if Honda didn't make the driver side top mounting bolt so difficult to access. Hah!
Have to remove the plastic cowling between the hood and windshield, as well as the wipe arms and wiper controller assembly (not sure what they're called).
Hot tip: For lining up the knuckle and the strut, I like to use my knees to hold and guide the rotor.
The ride quality is so much better! This car has always had a slight knock in the front right side since we got it. Now it rides like a newer Fit!
Oil leak
Checked the PCV valve. It's fine. Cleaned the MAF sensor. I have the o-ring for the thrust cover seal and the VTEC solenoid gasket. I might do those at some point. Definitely going to do the Valvoline Restore & Protect at the next OCI or sooner. I think with R&P, you had to do three shorter OCIs.
Transmission fluid
I'm going to try Valvoline MaxLife and some Lubegard. I think many folks here swear by Honda DW-1, and that's what I've been using. Folks over at BITOG swear by MaxLife. So I figured I'd give it a try.
Lab results from most recent OCI attached, plus some fun photos. Had to get creative with creating more shade in my condo parking lot. Also grabbed some photos of the other rubber bits because I have all of the parts to replace them. But these look practically brand new! Also inspected the brakes because they were making a squealing noise a couple days prior, but there must have just been a rock up in there or something, because the rotors and pads look great.
Old Jun 22, 2025 | 09:50 AM
  #42
GrE8_Fit's Avatar
Awesome work! Perfect weather for knocking projects off the list, I'll have to get crankin.
Old Jun 22, 2025 | 11:37 PM
  #43
uRabbit's Avatar
Definitely! I’ve officially overbooked myself, though, and have neglected to go camping yet.
Old Apr 18, 2026 | 10:28 AM
  #44
uRabbit's Avatar
Last oil change, at 173,170 miles, I replaced the oil I was using with Valvoline Restore & Protect. Filter I'm using is still the Premium Guard PG4612EX.
I was reinstalling the all-season tires and decided to change the oil again at 176,950 miles. In less than 4,000 miles, the oil was down to 1/3. Only ~1.25 quarts came out when drained.
This is a known issue with Betty, and has been happening for the last couple of years. I'm hoping that R&P will help, but I'm not putting money on it. I don't know anything about oil burning or leaking, but I'll need to get to the bottom of this. No leak spots in the driveway, and can't find any inside the engine bay.
Old Apr 19, 2026 | 09:41 PM
  #45
OliveOil's Avatar
I’d keep doing another few OCI’s at 5k miles with R&P . See what happens. I would just use this oil for the remainder of its life. It can only help
Old Apr 28, 2026 | 08:11 PM
  #46
uRabbit's Avatar
Definitely keeping at it, but at 5,000 miles, I think it'd be without oil. Hah! Last oil change, I'd added 1/4 of a quart in the middle of the OCI.
Old May 6, 2026 | 11:38 AM
  #47
uRabbit's Avatar
Betty's most recent oil analysis just came through. Betty is still consuming oil somewhere. I'm not sure how to diagnose that, but I'll continue my research.
Old May 17, 2026 | 04:48 PM
  #48
uRabbit's Avatar
I've been working on fixing Betty's A/C for years now. So far, I've replaced:
- High and Low side valve cores.
- Condenser
- Drier
- Evaporator core
- Expansion valve
- Blower resistor
This week, I'll be replacing the blower resistor again, and the blower itself.
And yes, I really did do the evaporator core and expansion valve myself... It was not fun.
I'm having a shop take a look at it after it's all put back together, so that they can perform a vacuum test and help identify any points of leaks if there are any.
Old May 18, 2026 | 03:10 PM
  #49
Detergentcandy's Avatar
Well hopefully they can find any final leaks! AC work is never easy so well done on what you did do!
Old May 22, 2026 | 12:25 PM
  #50
uRabbit's Avatar
Thanks! It's been a PITA, so I'm looking forward to not having to deal with it again.
They finished work on it, and said they replaced the expansion valve again. I'm not super happy about that, but oh well. All in, it was $1,250. Hoping they actually vacuum tested it and confirmed no leaks like they said.
Old Yesterday | 11:51 AM
  #51
If they didn't, hopefully you can take it back under warranty without paying extra?
string3599
17
Aug 25, 2019 10:40 PM
ge813sport
Nov 18, 2017 08:34 PM
isis07734
Jul 7, 2015 10:17 AM
tafkam
Mar 7, 2013 07:54 AM
footloose
Jul 4, 2009 09:51 AM
