My progress. Slowly but surely (College Student Budget)
Old Apr 11, 2012 | 05:20 AM
  #41
krunk13's Avatar
Imagine a 16 foot or 17 foot wheel, would take quite a bit of torque to get those moving.
Fit donk
Old Apr 11, 2012 | 11:44 AM
  #42
pandayun's Avatar
took some better shots, and they are 17" ^^;; thx guys
Old Apr 11, 2012 | 12:47 PM
  #43
krunk13's Avatar
Specs on wheels please.
Old Apr 11, 2012 | 02:06 PM
  #44
pandayun's Avatar
lol another shot, specs at 17x7 offset 42+ running 205/40/17 but I'm back on stockies until I get new tires.
The one's that came with the wheels vibrate a lot, something's off so I should just replace all 4. Going to cost me >_< but it's better then driving dangerously.
Old Apr 11, 2012 | 02:12 PM
  #45
lowkeymods's Avatar
I'd get them looked at by a local tire shop before replacing them.
Old Apr 11, 2012 | 02:15 PM
  #46
pandayun's Avatar
They have no leaks or bends, all straight. I believe the vibrating is because I am using two different tires in the front. One with 80% toyo proxie and one brand new nitto, same size but different tread pattern. Not sure what else can cause vibrating.
Old Apr 11, 2012 | 06:37 PM
  #47
doctordoom's Avatar
Supervillain
Have you ever had them checked for balance and straightness, or did you just visually inspect them for bends? It's better to use a wheel balancer.
Vibrating from wheels/tires is usually from imbalance, bends, or improper installation (in some cases not using hubcentric rings). Different tires might be noisy but shouldn't make your car vibrate.
Old Apr 12, 2012 | 11:24 PM
  #48
slp950's Avatar
I agree with doctordoom. Having worked in a very busy tire shop for 5 years plus run a bunch of different wheels and tires on 20+ cars, I can say from experience mis-matched tires will not cause a vibration.
I would suspect either a bent wheel, a flat spotted tire, a tossed weight, cupping due to mis-alignment, or it could be a separation, or an impact break in the sidewall of one of your tires. Definitely have a quality tire shop inspect your wheels and tires before you go spending a bunch of cash that may not be necessary.
Old Apr 12, 2012 | 11:31 PM
  #49
krunk13's Avatar
Maybe he came into a bunch of cash recently. Spending that scholarship on your car huh
Old Apr 13, 2012 | 04:18 AM
  #50
lowkeymods's Avatar
I had a real nice guy at my local tire shop put them on the balancer and inspect them for free when I thought I might have a bent rim/slipped belt on the tire. It shouldn't cost much and should give you a less expensive alternative...especially if you already have them off. Magic seats...get ready to haul some wheels/tires.
cyanosis
Jul 1, 2015 02:27 AM
MR-GE8
Aug 13, 2010 09:09 AM
Darkstars
Mar 27, 2008 12:29 AM
Darkstars
Mar 22, 2008 08:40 AM
Bahumut
77
Dec 9, 2007 11:12 AM
