HKS Hipermax S Compact installed
Old Feb 11, 2010 | 09:27 AM
hanzo's Avatar
Do you need a spring compressor or other special tools to install it? Also how to you adjust the front damping, do you have to undo the entire wiper cowling again?
Old Feb 11, 2010 | 07:43 PM
jookybanana's Avatar
they look like this, minus the sway bar end links, so its basically remove the stock units and installing these
Old Feb 12, 2010 | 01:36 AM
clay7160's Avatar
tein or hks do not include upper mounts from what i have been told and researched....out of all the coilovers readily available in the US, tein and hks have the most street friendly spring rates that i have found.....but tein are about 200-300 cheaper (for the tein s.s.) and they are supposed to be able to drop the fit a little lower.......
Old Feb 17, 2010 | 10:34 PM
HKS does have top hats, only tein dont have them, so no spring compressor needed
but the hks still require that oem top rubber piece which i think every coilover has to re-use that
Old Feb 18, 2010 | 07:44 PM
jdmstop's Avatar
looks great, can anyone recommend a good quality lowering springs for the fit with stock shocks?
Old Feb 20, 2010 | 03:04 AM
clay7160's Avatar
Thanks for clearing that up....my info was incorrect...
Old Oct 7, 2010 | 10:55 AM
ellisonrox's Avatar
any update on the coilovers? i've been wondering about them.
Old Nov 10, 2010 | 11:54 PM
drumsauce's Avatar
The Tein Super Compacts (equivalent to the SS, so i'm told) DO have the top hats (if that is what they are called) but you need the smaller rubber mounting piece that goes over the rod on top of the "hat," plus the lower rubber and upper rubber to mount to the shock tower.
VRsean
Aug 30, 2012 02:58 PM
vvs
30
Jul 29, 2010 02:53 AM
F033x
Jan 26, 2009 06:51 PM
bigg_kidd
27
Aug 19, 2008 01:54 PM
F'it_ImFromTx
Apr 1, 2008 08:51 AM
