The GE FiT Swift Springs thread
Old Aug 1, 2012 | 11:31 PM
  #81
dtfdanyo's Avatar
Man I'm jealous of you 2nd genners and your Swift Springs
Old Aug 1, 2012 | 11:40 PM
  #82
Goobers's Avatar
The first gen has Swifts for it too... though, a bit stiffer (front 3 vs 2.3, rear 5 vs 2.1).
If you want to look for it... 4H912
edit: hum... just how different in actual dimensions are they? Any first "genners" want to try putting a 2nd gen set of Swifts on their Fit?
Old Aug 2, 2012 | 02:54 AM
  #83
Texas Coyote's Avatar
I have a set of Swift Mach springs for a GD3 if anyone is in the market for some.
Old Aug 2, 2012 | 08:00 AM
  #84
555sexydrive's Avatar
Goobz, the chassis is MUCH stiffer in the GE, even stock spring rates are quite different between the 2 models. Reason why the big difference in rates. You may have known this already, but I believe not everyone knows.
Old Aug 2, 2012 | 05:34 PM
  #85
Goobers's Avatar
Nope, I did not know that (or if I did... I surely forgot it).
Old Aug 10, 2012 | 12:23 PM
  #86
Kee's Avatar
Kee
Hey all I have been lurking since I bought my fit a month ago and I have been reading all the swift spring threads I can. I have my springs just waiting for a free weekend to do the install.
The question I had was do I need to cut the bump stops or not?
I have see conflicting posts from members regarding the bump stops and the swifts.
Old Aug 10, 2012 | 12:42 PM
  #87
I helped install Swift springs on a GE a couple of years ago and we didn't cut the stops.... I had to on my GD though.
Old Aug 10, 2012 | 01:09 PM
  #88
dtfdanyo's Avatar
^pm'd you Coyote
Old Aug 10, 2012 | 03:18 PM
  #89
Kee's Avatar
Kee
Hmm. Thanks coyote Im thinking of just not cutting them. I guess worst comes to worst I'll have I take things apart again.
Old Aug 10, 2012 | 04:42 PM
  #90
Black3sr's Avatar
Do not cut them. I went through this when I was gong to install mine. Somewhere there is confirmation you do not need too.
Old Aug 10, 2012 | 07:21 PM
  #91
Btrthnezr3's Avatar
I'll +1 for not cutting the bump stops.
Old Aug 10, 2012 | 08:49 PM
  #92
krunk13's Avatar
Why would you ever need to cut bump stops.... aren't they there to stop shock damage?
Old Aug 11, 2012 | 02:22 AM
  #93
Kee's Avatar
Kee
Good info thanks guys seems like everyone is on the same page.
Old Aug 14, 2012 | 01:34 PM
  #94
Kee's Avatar
Kee
Thanks for the info again all. Springs are all in and the car handles great. One last question, my car seems to be tracking well but the steering wheel is slightly off kilter. Do I just need to get an alignment?
Old Aug 14, 2012 | 01:40 PM
  #95
lowkeymods's Avatar
Yes...asap.
Old Sep 17, 2012 | 07:47 PM
  #96
zilla8's Avatar
I have a question for others running Swifts on GE8
I've had my Swifts on for a couple of months now and have no issues but I still need to get a alignment.
I have even tire wear and no rubbing with 205/50/16 on stock 12 sport wheels
but I'm wondering if I should run -1* with camber bolts when I do the alignment.
I'm not tracking or auto X just like to hit the canyons every chance I get
Old Sep 18, 2012 | 11:07 AM
  #97
zilla- if you're happy with how the car is running i suggest you get just the toe aligned.
it is a good idea to have camber bolts installed even if you dont plan on dialing-in additional negative camber. you can match the camber left/right with the bolts if they are off. without the bolts the shop can't really do anything to adjust.
the SPC bolts can be had for less than $30 from tirerack, so it's really up to you.
i have a set installed, dialed in -1.5 camber with zero toe. works very well for me.
Old Sep 18, 2012 | 08:54 PM
  #98
zilla8's Avatar
Sounds good I'll pick up the cam bolts and run just a tad of neg camber with 0 toe.
I love the Swifts and even with the whole Family riding along they continue to impress
Old Sep 19, 2012 | 10:30 AM
  #99
yep, im real surprised how well they match the stock dampers.
Old Oct 2, 2012 | 02:31 AM
  #100
Bluflu's Avatar
with so many different spring types on their site, how do you know which one to aim for?
or which spring type is recommended (sport, spec R)?
