Honda Sport Suspension
Old Sep 12, 2010 | 12:46 PM
B-Blue's Avatar
Question Honda Sport Suspension
Not sure if this has been covered or not, but looking through japanparts.com I came to this:
Are these anything special? Is it for the RS?
Old Oct 13, 2010 | 08:27 PM
555sexydrive's Avatar
It's for all the models here. It's Honda Access Sport sussy, it lowers about 25mm(1"). It is what is on my RS till I decide to upgrade to something more if I do at all.
They have versions for 15" wheels and 16" wheels, not exactly sure what is different between the 2 versions, but they exist. Spring rates are not known, well not advertised, but I would imagine they are equal or slightly stiffer than the stock setup.
Old Nov 6, 2010 | 09:42 PM
phenoyz's Avatar
[quote=B-Blue;909541]Not sure if this has been covered or not, but looking through japanparts.com I came to this:
Are these good ???
Old Nov 6, 2010 | 10:05 PM
johnkimble's Avatar
haha dude phenoyz he just said he has them on his car
Old Nov 19, 2010 | 04:38 PM
cHaNkStA's Avatar
johnkimble, does the word ephatch sound familiar to you?
Old Jan 27, 2011 | 12:58 PM
Goobers's Avatar
please excuse the thread revival...
my friend is planning on going for some "performance" struts for his Corolla... and I found out, they're pretty hard to find... and same for the Fit.
in anycase, I landed here during my search.
is it me, or do those springs look an awfully a lot like Swift Springs?
Old Jan 28, 2011 | 12:25 PM
blackndecker's Avatar
It would be easy to distinguish if the Swift springs are "counter wound" meaning the springs are assymetric and rotate in opposite directions. <-- this the preferred orientation for spirited driving. The springs above are symmetrically wound (likely for mass production and cost savings).
Old Jan 28, 2011 | 12:47 PM
Goobers's Avatar
huh?
https://www.fitfreak.net/forums/fit-...tml#post953683
i dunno.
: okay, the swifts looks like it has one more winding overall in the rear. fronts look about the same.
Old Jan 28, 2011 | 12:58 PM
Look at the springs above. Look at the direction that they are wound. I was referring to the orientation of winding. In the pic above, the L and R springs wind in the same direction as opposed to rotating in opposite directions (clockwise and counterclockwise).
Doesn't matter anyways...apparently these are not swift springs. Swift springs use a "less coil" design. The rear springs posted above have close coiling. Clearly, the rear springs are different.
Old Jan 28, 2011 | 01:13 PM
Goobers's Avatar
the pic you posted is generic.
the Swift springs for the GE Fit have the same "close" coiling at the bottom, hence the link i posted.
(i installed a set earlier this week).
btw... i think you're mixing the term... asymmetric would be the way they are now... both side wound the same direction. because to be symmetric, it has to "mirror" about a point or line. obviously, it can't be symmetric around any line within the body of the coil otherwise, you'd have a criss-cross pair of windings. so, to have symmetry, you choose a line about the middle of the car and then one side has to wind opposite of the other. all the pictures listed make asymmetric setups.
Old Jan 28, 2011 | 03:35 PM
They still look different to me. I see 2 coils above the small coil in the first pic, and 3 coils above the small coil in the second pic. Subtle, but different nonetheless.
Thanks for the link BTW.
Old Jan 28, 2011 | 03:41 PM
Thanks for the clarification. I've read that "symmetrically" wound springs make a significant difference on the RSX front McPherson strut style suspension.
I wonder why Swift chose not to make symmetric springs for the Fit?
Old Jan 28, 2011 | 10:19 PM
Goobers's Avatar
Probably because you'd then have to modify the way they mount. More trouble than its worth for a product they tout to work with stock struts.
As it is now, its a direct swap with the stock parts.
Old Jan 28, 2011 | 11:37 PM
danger69's Avatar
Now we know the GD3 suspension fits the GE8 how bout vice versa?
mecevans
Apr 25, 2014 11:17 AM
cjecpa
Jan 8, 2013 10:12 AM
JoelR
65
Feb 24, 2012 09:06 PM
SIL48
Nov 16, 2010 03:53 AM
xmathx
Mar 20, 2009 05:18 PM
