Sportline and Eibach Camber Bolts
Old Feb 12, 2012 | 07:50 PM
BlueBoogers's Avatar
Do these two together allow for factory alignment?
How far out of whack do just springs make the alignment?
Old Feb 13, 2012 | 04:21 AM
superdat1's Avatar
my camber moved but stayed in spec. my right toe moved .5degrees but even then stayed in spec.
i don't think you'll need an alignment but if its worth the peace of mind...
Old Feb 14, 2012 | 05:30 PM
RevToTheRedline's Avatar
I'm lowered on Tanabe DF210's and my front negative camber is all out of whack, will camber bolts correct that for me?
Old Feb 14, 2012 | 08:13 PM
NewFitGuy09's Avatar
are you lowered on eibach sportlines???
Old Feb 15, 2012 | 10:46 AM
Jackson's Avatar
Yes, the camber bolts will allow you to align back to factory specs with the Eibach Sportlines. Just make sure you get the toe alignment adjusted as well.
Old Feb 15, 2012 | 05:53 PM
superdat1's Avatar
yes i am..
Old Apr 8, 2012 | 01:04 AM
TheDilweed's Avatar
i'm on sportlines but i didn't need to use the camber bolts. so i have 2 sets (accidentally ordered 2) that i didnt use. la;ghaklejtha
Old Apr 20, 2012 | 10:42 PM
dcmcelreath's Avatar
I wouldnt recommend the eibach camber bolts. We lowered our car today, and I installed the eibachs when I put it all back together. The nut was out of round on the end, and was a bear to thread on all the way. I think they need to do a better job making the nuts
soobieajax325
Jul 3, 2017 10:02 PM
NewFitGuy09
Mar 13, 2012 01:28 PM
GD3_Wagoon
May 25, 2010 12:11 AM
henryd1981
27
May 17, 2008 04:16 PM
bdk323
Apr 17, 2008 10:57 PM
