Shape & Dimension of Hub that Touch Rotor Center Bore
Old Mar 31, 2013 | 03:09 AM
BMW ALPINA's Avatar
Hello,
I never took out Honda Fit GE Front Brake Rotor so I want to ask you guys who had done it.
We know that the diameter of the Hub that hold the Wheel for Honda Fit is 56.1mm
But how about the shape and diameter of the hub that hold/engage with the Rotor's center hole ?
Is it also 56.1mm ?
or it is FLARED to be a little bigger then the 56.1mm ? how big is it (the diameter)?
if they were flared, what kind of shape, are they a STEP type flared,
or flared smoothly with an angle?
Did any of you have clear close up picture of the hub without the rotor?
I really want to see the shape of the hub that hold/engage the rotor's center hole.
Thank You
Old Jun 7, 2013 | 01:13 AM
BMW ALPINA's Avatar
I forgot that I already had answer to this question myself since I had taken out my rear disk brake assembly...
Ok, so the part of the hub that hold the rotor is 61mm in diameter and it is not flared.
Here are the pictures:
Paulo107
Apr 10, 2015 12:04 AM
ghg78
Sep 19, 2010 05:00 PM
Swimmer Boy
Feb 16, 2009 10:56 AM
Burbio
Oct 19, 2008 06:17 PM
kkim
May 11, 2006 03:10 PM
