Wilwood release new caliper for Honda, No Bracket needed, Direct Bolt On
Old Nov 28, 2014 | 10:28 AM
devmail's Avatar
3.9 lbs for this caliper, down from 8.5 lbs (roughly) stock caliper. Me wikey vewy much!
Old Feb 22, 2016 | 02:32 PM
bensenvill's Avatar
so has anyone done wilwood fronts yet? I'd really like to pick up the kit as I'm changing up everything else, but would like confirmation that it really is plug and play.
Old Feb 22, 2016 | 03:27 PM
linus011's Avatar
I installed a set about 2 years ago. They were a snap, and have worked great since! I say go for it.
Old Feb 22, 2016 | 06:01 PM
devmail's Avatar
I'm a complete noob with brakes and I put these on with no problems, directly bolts on, no other parts required save for some brake fluid to bleed the system.
Attached Thumbnails Wilwood release new caliper for Honda, No Bracket needed, Direct Bolt On-c72ce2d4-d21f-404a-a123-b3dcf0a8d2bf_zpsjl6udmrk.jpg   Wilwood release new caliper for Honda, No Bracket needed, Direct Bolt On-62e93400-6ce5-4e6a-9582-9d6a282cfe8b_zpsfkysnfvo.jpg
Old Feb 22, 2016 | 07:14 PM
shinjari's Avatar
Great....something to look forward to when my rotors go bad.
Old Feb 23, 2016 | 12:26 AM
bensenvill's Avatar
best news I have heard, thanks for the affirmation.
Old Feb 23, 2016 | 01:34 PM
dwtaylorpdx's Avatar
Just a couple cents worth,, I don't use the drilled rotors even on my track cars only the slotted ones, seen too many drilled rotors break. Brembo makes ones that hold up pretty well but the gain is only there at the last 10th so for a street car no way..
Old Feb 23, 2016 | 07:12 PM
Myxalplyx's Avatar
Mouth drops!
And they are beautiful too.
Still....4.5lbs drop in weight = Dayum!
How much do your rotors weigh vs stock? It's not in your weight list link.
Old Mar 15, 2016 | 10:00 AM
JazzITup85's Avatar
Do these fit fit the stock FIT 16's?
Old Mar 15, 2016 | 02:10 PM
devmail's Avatar
Originally Posted by Myxalplyx
Mouth drops!
The rotors are almost the same in weight, just slightly less because of the drilling and slots.
And these should fit 16 because they fit MOST 15s. I'm running the Integra LS mesh wheel with no issue and it's 15".
The only wheel I've heard these won't work with is the higher offset 15" enkei rpf1. The lower offset 35mm does work so I've read.
Old Jul 7, 2016 | 02:13 AM
phenoyz's Avatar
anybody using this brake set ?
is it good
Old Jul 11, 2016 | 08:26 PM
  #32
linus011's Avatar
They do fit the stock 16's (2009 Fit Sport) but the clearance is crazy tight. Like a 2mm gap.
Old Jul 12, 2016 | 10:53 AM
  #33
shinjari's Avatar
Which Wilwoods are you talking about? The ones that use OEM rotors or the 12" upsize/upgrade kit?
Old Jul 12, 2016 | 03:32 PM
  #34
linus011's Avatar
The ones that use the oem sized rotors.
Old Jul 12, 2016 | 06:12 PM
  #35
shinjari's Avatar
Damn...barely clear the 16" sport wheels huh...Definitely better measure my spacing with my 15" gram light 57dr's...would hate to order and they not fit. They do say "some" 15's will fit.
Old Jul 12, 2016 | 07:28 PM
  #36
linus011's Avatar
The clearance issue is between the spokes and the caliper, not between the outer ring of the rim and the caliper. I bet your gram lights will fit. You'll definitely want to measure though just in case.
Old Jul 29, 2016 | 04:08 AM
  #37
phenoyz's Avatar
Which ones are those?
Old Jul 29, 2016 | 03:36 PM
  #38
linus011's Avatar
http://www.wilwood.com/PDF/NewProduc...nt_caliper.pdf
You know, the ones this whole thread is about.
Old Sep 23, 2016 | 07:16 PM
  #39
owenxguo's Avatar
Old May 27, 2021 | 12:48 PM
  #40
Gk5hondajazz's Avatar
Wilwood
Guys im a newbie is this
Wilwood 140-12996-DR is plug and play in my gk5 with ng wheel +40 offset thank you guys and if anyone using it what are your feedback
