progress vs. swift springs
Old Oct 10, 2013 | 01:54 PM
cyanosis's Avatar
It seems like the swift springs and progress rsb are the darlings of this forum, I'm just curious if anyone is running the progress springs instead of the swifts. The drop is supposedly the same but the balance is drastically different. The progress are also a fair bit cheaper, though I'm concerned that they may be too harsh for a daily driver. (florida, roads are decently clear) Any feedback?
Progress Lowering Springs
F -1.2 in / R -1.0 in
F 2.8kg / R 3.6kg
Swift Sport Mach
F 2.3kg / R 2.1kg
Old Oct 10, 2013 | 02:21 PM
MNfit's Avatar
I had the progress lowering springs on my Fit. I live in Minnesota so the roads are not always the best, but I loved the springs.
Old Oct 10, 2013 | 02:42 PM
Wanderer.'s Avatar
I have not had the Progress GE8 springs, but I will opinionate:
That rear spring rate on the Progress looks a little high for stock shocks. The advantage of using the Swifts + RSB is with the RSB you increase effective spring rate, but only in corners, so straight line cruising comfort is hurt less. I have Teins and i've always felt the stock shocks could barely handle the rebound and their rates are lower. The unfortunate part about the Teins (for performance) is the drop, which puts the shock's piston a little outside of it's comfort zone I think. Looks good though lol. Progress may be better since it's not as low.
I am also not 100% sold on Progress' spring design. Not a lot of winds and stacked up progressive kind of sucks. Swifts are linear throughout.
I would think the Progress springs + Progress RSB would be AWESOME with upgraded shocks but there are none for the Fit that can be found cheaply. I suppose you could go with Koni Yellows on the rear turned down low to help handle that higher rate. They're not that expensive. I'd actually like to see that + review.
Just throwing thoughts around from my brain, bored at work
Old Oct 10, 2013 | 03:21 PM
cyanosis's Avatar
I didn't realize the progress were progressive. No pun intended. I agree that the rates are likely high for the OEM shocks. Furthermore, the progress setup seems like it would make the car a bit tail happy, especially in comparison to the swifts. I'm sure that their intended handling balance is track friendly but for the street I'm a little unsure. I may have to fork out the extra dough for the swifts. Are there any site vendors that have a discount on them? I'm afraid of knockoffs on eBay.
Old Oct 10, 2013 | 05:54 PM
cyanosis's Avatar
another point to consider is that the higher spring rate MIGHT reduce rubbing while turning as the suspension would theoretically compress less.
Old Oct 15, 2013 | 11:33 AM
Jango_Fit's Avatar
I had progress in my ge8 for 2yrs. Nice springs however for the minimal drop I received it rode a lot stiffer and harder like I went wayyy lower. I wasn't impressed with that. Otherwise good springs I just didn't notice it was really lower after install. Swifts rode OK IMO. But it looked stock height in appearance to me. I wasn't a fan of the swifts!
Old Oct 15, 2013 | 11:46 AM
cyanosis's Avatar
wish i'd seen this feedback sooner. lol. florida has pretty smooth roads so we'll see how it goes.
Old Oct 25, 2013 | 02:58 AM
kollunz's Avatar
How would these go with Koni SRT shocks when they're released?
Old Oct 25, 2013 | 01:38 PM
Texas Coyote's Avatar
The Swift springs are great with the stock dampers if you are fond of the way European cars handle and ride.. My only problem with them is that they lowered my car more than needed for use on the roads in this area... I finally got the ride, clearance and handling desired by installing Buddy Club N+ coil overs.
Old Nov 4, 2013 | 10:38 PM
SBFT09's Avatar
I have been on Progress Sport springs for about 25K miles now. They perform well, especially when daily driven. I only wish they settled a bit more, its really not too noticeable compared to stock height.
Old Jul 1, 2015 | 02:27 AM
space egg's Avatar
i just can't stop staring at this beautiful car
sultanofslide
Jul 11, 2014 12:41 AM
drifthunter
Dec 25, 2011 10:19 PM
Sherpa
Sep 9, 2010 12:15 AM
Darkstars
Mar 27, 2008 12:29 AM
Bahumut
77
Dec 9, 2007 11:12 AM
