got my new rims but looks like @#%?
Old Feb 5, 2011 | 07:15 AM
aqua-holic's Avatar
i just have my new rims, 7x17 with et 38 205 40 17
at the back the just look awesome but at the front...
the wheel is sticking out , and that looks like shit!
so at the back et 38 is good! but now i'm thinking to put on the front a wheel with et 45.
would that do the trick?
i know some guys have 38 and 45 so mayby they can give me the solution?
my car is a european car (holland) but i dont think that would matter?
sorry for my english,
greetings stefan
Old Feb 5, 2011 | 01:54 PM
Gbarb18's Avatar
A post like this is pointless with out pictures.
Old Feb 5, 2011 | 02:43 PM
aqua-holic's Avatar
i know,
i left the rims in the shop and forgot to take a photo of it,
but i think it stick out for almost a cm.
dus anybody have a good picture how much a ET 45 wil stick out?
Old Feb 5, 2011 | 03:21 PM
jdmgd4's Avatar
you can buy some front camber bolts and neg camber a lil to result in a lil more flushed look..jus my .02
Old Feb 5, 2011 | 03:39 PM
Goobers's Avatar
since you're willing to go with lower offsets anyway...
why not go with 45 all around... and then put a 5 or 10 mm spacer on the rear.
The only reason I'm chiming in... putting the same size wheel all around means you can continue to rotate the tires like normal.
Old Feb 6, 2011 | 02:42 AM
aqua-holic's Avatar
i choose not to use spacers because the 38 offset at the back is perfect!
at the front it's just popping out and that's not my thing...
but i wondered has anybody a good picture how the 45 offset will look like at the front? i allready search a bit but couldnt find one.
Old Feb 6, 2011 | 03:12 AM
aqua-holic's Avatar
i search a bit for those camber bolts, i keep that in mind!
but i hope the 45 offset would do the trick!
Old Feb 9, 2011 | 04:37 AM
Green karma's Avatar
Just imagine your current front wheels right now 7mm tucked in more. If you are under your fender you're cool. Or drop a line down your fender and see what the distance is between the string and the outer most distance to the outside of tire to gauge your distance necessary. I have at +42 offset all around if you want me to see/post.
Old Feb 9, 2011 | 05:46 AM
aqua-holic's Avatar
I really would like to see some pictures of your 42 offset
Old Feb 9, 2011 | 03:25 PM
Work XT-7 17x7 +42 Offset Lowered on Swift Springs. Just put it on so haven't really driven it yet. Will give you a report later if you want.
-J
Old Feb 10, 2011 | 03:03 AM
aqua-holic's Avatar
Okay that looks nice its almost straight with the bodywork?
thanks for the photos!
Old Feb 11, 2011 | 04:58 PM
jondotcom's Avatar
I think it looks great as long as they don't rub.
Where do you take if off-road at?
seeyalaterbye
Apr 24, 2013 09:21 AM
StormSurfer
Nov 6, 2012 07:19 PM
DAY54
Jul 7, 2011 10:32 AM
Fat Ping Cat
Feb 19, 2009 12:23 AM
nikeflex
Feb 26, 2008 07:00 PM
