Question about 16x7.5" wheels
Old Feb 8, 2011 | 10:10 PM
J.M.P's Avatar
I am wanting to buy a set of Kosei K1's that are for sale locally. I want to know if they will rub or not. The size on them is 16"x7.5". Offset is +32. I know this size rubbed with tires on my Integra, but not sure on the Fit. Its a 2010 Sport.
Also, if these won't rub, what size tire would you recommend?
Also I guess I will ask, what size wheels with offset would be the best bet. I would like to stick with 16's, maybe 17's.
Thanks so much guys.
Old Feb 9, 2011 | 08:38 PM
J.M.P's Avatar
Anyhelp will be appreciated. I will keep searching, thanks.
Old Feb 9, 2011 | 10:11 PM
angryfit's Avatar
why not just go check them out and put them on the front the back should be fine though... are you stock height?
Old Feb 9, 2011 | 10:14 PM
J.M.P's Avatar
As of right now I am stock height. I would like to just put some springs on at some point. I am more than likely going to buy them anyways. but wanted some input before hand to ease my mind.
Old Feb 10, 2011 | 01:18 PM
beangrower's Avatar
at stock height...no problem. lowered...it depends how low you go and what tire size u run. the rears should no problem lowered. the fronts might be some concern when lowered. Here's my old set which is the exact same specs: 16x7.5" +32 offset. the tires are 205/40 in the front and 205/45 in the rear. I bought them used and these are the tires it came with.
...and here it is photoshopped slammed. lol.
Old Feb 10, 2011 | 01:31 PM
J.M.P's Avatar
^^^ Thanks for the great reply I needed, haha. I do want to go a little lower. I am thinking on going 2inches at the most lower. I haven't even started shopping around for springs or coilovers yet though.
danielabel
Apr 21, 2018 06:22 AM
jcuecker
Feb 3, 2011 11:57 PM
bcr888
Jul 9, 2009 10:45 AM
xpoxpo
Jul 2, 2009 12:32 AM
HONDAJUNKIE
Jun 16, 2008 11:19 AM
