Will ANY 4x100 bolt pattern wheel fit the GE8 fit?
Old Oct 15, 2011 | 01:37 PM
concorde's Avatar
Comment has been removed.
Old Oct 15, 2011 | 01:45 PM
ill_eagle94's Avatar
You're going to need to make sure that they are the proper offset for the Fit. I am not certain of what offsets will be safe but if it's not enough backspacing, you can always fix that with spacers.
Old Oct 15, 2011 | 04:14 PM
Bthasht's Avatar
As long as it has a 4x100 bolt pattern it will bolt up. Offset is key with any wheel choice. Any mini cooper wheel will bolt up no problem with their offset. Offset is also the problem as well. People on this site have ran 16x7 +13 fronts and 16x8 +25 rears. Also 0 offsets have been seen. It all depends on what look you are going for.
My GD runs 17x7 +42
Old Oct 15, 2011 | 07:32 PM
vinnymac's Avatar
Also, keep in mind that just because the bolt pattern is 4x100 doesn't automatically mean that they will fit. While having sold several sets of wheels I found that the lugs on the car makes a difference, they have to be a certain length . For instance a set of wheels (Aftermarket) that I took off my ryde would not work on a 08 nissan sentra and a couple other cars that I tried... Tried several dif. lug nuts too!
Old Oct 15, 2011 | 07:43 PM
solbrothers's Avatar
offset and center bore matter as well. also 17.5 wheels?
Old Oct 15, 2011 | 10:47 PM
Center bore and offset like Sol said.
Old Oct 18, 2011 | 12:28 PM
neil patrick harris's Avatar
and most aftermarket wheels need cone seat bolts.
Old Oct 18, 2011 | 08:18 PM
oh okay. you put 17.5 and that worried me. lol.
my buddy has 15.5 or 16.5 diameter wheels and can't find tires for them :/
Old Oct 18, 2011 | 08:36 PM
no problem man! im not sure if they make 17.5" wheels but if they do, RUN AWAY! sounds rare and expensive when it comes time to buy tires
Old Oct 24, 2011 | 06:17 PM
Fit4Spl's Avatar
Will these work on a 09 Fit?
16x7.5 4x100/114.3 +38 offset.
Old Oct 24, 2011 | 06:39 PM
you're probably going to rub unless you get some stretchy tires. 205/50/60 will definitely rub.
Old Apr 29, 2012 | 09:35 PM
TheDilweed's Avatar
What about 16x8 +20? Center bore is 57.1.
I know Ill need to roll my fenders but will the wheel be mexiflush status?
Peter Nguyen
Apr 18, 2017 12:41 PM
VBP08GD3
Feb 3, 2009 11:53 AM
DrDiff
Mar 21, 2007 11:18 AM
CJSCJS
May 11, 2006 05:01 PM
Buddah
Canada Fit Forums & Clubs
Apr 3, 2006 10:36 PM
