about to order wheels
getting ready to order some wheels and just want to make sure I will not have any rub issues. the wheels are 16x7 +45mm offset and I will be running the stock 185's for now. I am lowered on swift springs. Input is greatly appreciated!!!
45 mm Offset is where you want to be with no issues... and with a 185 tires you for sure will be ok. some people on here are 205 50 16 on a 16 x 7 45mm and no issues on SWIFT springs.
thank you, that is what i wanted to hear
Would you guys recommend getting hubcentric rings? the bore is 67.1 vs the 56.1 stock honda bore. Is the wheel shaking/vibration bad without the hub rings? Also, do the stock lugs work or do I need aftermarket ones and what size? is it 12x1.5?
you need hubcentric rings and yes you need lug nuts that are for aftermarket wheels
what lugs would you recommend? and is the size 12x1.5? or 1.25? Also, where can you purchase hub rings from?
Gorilla Automotive 71733 Acorn Chrome Lug Nut and Lock System (12mm x 1.50 Thread Size)
will these work guys? |
Originally Posted by liverpoolfcfan
(Post 1089089)
will these work guys? also, what do you guys think of these hub rings? any good? I am not sure who is a reliable source for hub rings http://www.ebay.com/itm/POLYCARBONAT...sories&vxp=mtr seems pretty cheap to me for 4 rings, i don't know |
