Would 16x7 6mm offset
a 6mm offset? The OEM offset is something like +55. You will definitely need a serious roll and pull if you're trying to run 6mm.
People running 7" wide wheels with +35 offset is pretty flush front. So 35mm - 6mm...would mean your wheel would stick out past the fender by 29mm (> 1")
I'm running 8" +35 and I have like 6mm of poke in the front which camber fixed, but pretty flush in the rear.
linnboi
07-20-2012 12:43 AM
