Installed those TRS Morimoto LEDs
I installed these before taking my family to Disneyland. I didn't take off the bumper thanks to your pictures I see where the tabs are. What I did was remove the screw securing the flip under the bumper where you excess the bulb if you want to replace it. I reach my right hand inside and pushed the tab and slowly pry with my other hands from the outside. It took me a total of 15mins to change. I had the LED cree h8 in my fogs before this TRS and notice the output wasn't so bright so I bought these thinking it was going to be brighter. Well after driving 8hrs from San Francisco to LA at 3am turing off and on my fog lights. The LED cree and TRS brightness is about the same, The TRS is just a little brighter but not for $70 more =(. I think the reason why the fogs isn't bright is because it sits so far in the bumper. anyways here is the link for the LED cree. Im gonna post mine on craigslist for $50.
http://www.ebay.com/itm/2014-New-40W-4800-Lm-Cree-LED-Headlight-Kit-Bulb-9005-9006-H8-H11-H4-H7-/131224044422?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e8d900386&vxp=mtr
There is only two screw holding the foglight in place, one on the top left and one on the bottom right side. These fog is height adjustable with a Philip screw driver from the bottom.
2014 New 40W 4800 LM CREE LED Headlight Kit Bulb 9005 9006 H8 H11 H4 H7 | eBay
I just ordered a set of TRS fogs, but I may end up giving these to my brother..
this is very surprising to hear. w/ my stock fogs + PNP HIDs, they point almost straight down and don't do much. they illuminate to the sides slightly, but that's about it. per the TRS website, the LED fog emits 1200 lumens per fog. for 35watt PNP HID kit, it emits 3200-3400 lumens per bulb.
have you tried aiming them higher so they project farther?
You'll have to aim them, and don't expect to be able to see much difference if you already have PNP hid in your stock halogen headlight housings.
Put on the regular halogen bulbs in the halogen headlight housings, then compare the TRS to the Cree fog light bulbs. Its a night and day difference. I would know because I spent about $150 trying three different "Cree led" bulbs from amazon and eBay and they all suck compared to the TRS. Heck I even have the same exact Cree bulb u listed here. It was so embarrassing to have on, I purposely parked in front of a house, unplugged my halogen housing bulbs and had only the Cree fog light bulbs on, only to see they illuminate the house and the second floor in front of me. Fog lights are not supposed to do that. Go to hidplanet and you'll see a bunch of other people telling you those Cree aftermarket bulbs arent any good without proper projectors designed for LEDs.
I also learned today you can stick a flat plastic trim separator tool in one side of the fog lights, then slowly pry the other side with your fingers and also pry from the shroud hole to pop the shrouds off without going under the flap or removing the bumper.
Have you tried to aim the trs higher? I am afraid to aim too high and blind people. I rather not cause a accident.
from the pics above, the TRS fogs look to have a sharp cut-off so you won't blind people (unless you aim it straight for their face). this is the main reason why i wanted to switch because they look to have a much more even spread. with OEM fogs + PNP HIDs, they are two big hotspots on the ground
Edit:
I also realized from the ebay link you posted and also a crucial element to the LED bulbs is that the Crees are supposedly pulling "20W" while the TRS bulbs use THREE 3 watt LEDs for a total of 9W. That's 40 W of power for the Crees with two fog light bulbs on versus 18 W of power for the TRS. Here's another on/off pic in the morning.
If you have HIDs in your stock headlights aimed too low, it'll drown out the spreads of foglights, but if you aim the foglights too high, it defeats the purpose of foglights. I had the foglights aimed higher than in those pictures, and it looked really cool having good spread and making my halogens look like HIDs because when I drove next to Porsches and Benz on the pasadena freeways at night, my Fit headlights literally looked as good as theirs and with coverage as good as theirs. But I've aimed them lower since then because foglight spread & distance shouldn't be reaching that far down the road to begin with.
#32
I should've taken a pic of them while I was facing the neighbor's white wood fence. It really showed off the fogs well, but then I'd be blocking the street.
When I googled how to aim them, I ended up having to use the underground parking garage at work because they had the most leveled ground (my driveway isn't level) so I did it from work. Basically I parked about 3-4 feet from the wall, turned on my lights, then tape measured the floor to the center of my fogs. Took the height, and measured from floor to the height on the wall and placed tape there. I then aimed the fogs cutoff to the tape.
After that I reversed to the parking spot behind me which is about 20 feet from the wall. Then I turned on the fogs again and checked the cut off to make sure it didn't bleed into my halogen headlights (kinda like in one of the pics I posted here). I also checked the SUVs parked in front of me to make sure the fog lights weren't reflecting off their license plate since the projection of the fog lights shouldn't go that high. If anything, it should only be reflecting off their mufflers.
The TRS LEDs also cause a bit of glare, not really glare to oncoming drivers, but I noticed there's glare for pedestrians walking outside. I'm not sure if this is meant to highlight pedestrians walking on the sidewalks at night but I didn't want to annoy them, so I covered the top 1/4 portion of the LEDs with some lamin-x smoked covers to reduce the glare to pedestrians. hmm... kinda like the JDM LED foglights for our GKs.
#34
Yea they have a screw to aim them up/down. And yea Japan has a set of oem LED fogs (not standard, optional equipment) that go for about $200 before shipping through rakuten.
They also get leather door arm rests optional, which blows my mind why Honda didn't include those for the Ex-L trim.
#36
I don't know if you can get them brighter. How do you have your HIDs aimed? If they're aimed too low, the fogs aren't going to help since the ground in front of you is already lit up by the HIDs. I don't think 1400 or so lumens can ever compete against the 3800 or so that HIDs produce. Cuz of that, u might wanna check your HIDs first.
#38
Yea you might wanna check your HIDs or leave them the way it is if you like it. When I put in the PNP HIDs into the stock housings before adjusting, they were aimed way too low. If you don't wanna be too technical, u can park next to another car with a wall in front of u, reverse about a car and a half length, then see if the HID beam pattern hits their side mirror. It shouldn't but you should be able to see some of your HID light a littlw below their door handle. Like I said, its not technical, but its a quick way to aim the lights when u have to for whatever reasons.
