3rd Gen GK Specific Fit Interior Modifications Sub-Forum Threads discussing interior modifications for the 3rd generation GK Honda Fit
Sport Pedal install?
Old Jun 19, 2015 | 09:15 PM
Darkshowdo's Avatar
Any idea how to install the Ebay Sport pedals?
I received 4 Screws Which i assume is for the dead pedal? since you cannot take the rubber pedal off for it.
Then received 5 Short bolts and lock nuts, which i assume are for the Clutch and Brake pedal? these seem simple just drill into the metal pedal.
As for the Accelerator pedal i received 3 longer bolts and lock nuts.
It doesn't look like the its a rubber cover on the accelerator, more like a plastic one?
any idea on the accelerator?
or a proper way to install these?
http://www.ebay.com/itm/New-Aluminum...6f6e46&vxp=mtr
Old Jun 19, 2015 | 09:17 PM
xxryu139xx's Avatar
would be nice if u post the specific item...
Old Jun 19, 2015 | 09:20 PM
Darkshowdo's Avatar
Was actually searching for that sorry,
here you go
New Aluminum Foot Rest Fuel Brake MT Pedals Fit for Honda Fit 2014 2015 4pcs | eBay
no instructions came with it, just confused i guess lol.
Old Jun 26, 2015 | 01:28 AM
roksta's Avatar
4 screws for the dead pedal you can just screw directly through the stock plastic. There's just a chunk of styrofoam under it.
For the other pedals you have to remove the rubber covers and drill holes. The gas pedal is plastic so I just drilled right into it.
I skipped all the nuts/bolts and used pop rivets instead for everything but the dead pedal.
Fit4Pits
Mar 15, 2015 07:56 PM
LDO
Dec 10, 2013 12:34 PM
boatfloyd
Nov 27, 2013 11:41 PM
worditsmenick
Mar 25, 2013 09:22 PM
koolkevin1107
May 2, 2008 09:04 AM
