New 'used' Fit owner! 2 questions
Old May 8, 2021 | 09:04 PM
GAMiniMiniVan's Avatar
Hey everyone! I just got a 2015 Fit LX with ~57k miles on it. Pretty excited about it and already loving it! The extent of my car maintenance "expertise" is oil changes and bulb replacements, but I'm wanting to learn more about my car and take proper care of it! I've been stalking the forums for a bit, so apologies if this has been answered.
1. Previous owner kept detailed oil changes and tire rotations logged. I didn't see transmission fluid change, so I will be doing that asap. Anything else I should look for (new to the Honda world as well. Valve adjustments?)?
2. Looking inside the car, I noticed 2 areas where there are threads but no bolts. First is near the engine dip stick. Other is under the air filter (attached photo). Anything I should be concerned?
Old May 9, 2021 | 01:33 PM
Azuki's Avatar
Congrats on the new to you Fit! There are some threaded holes that don’t have anything in them, thats normal. I can’t tell what the first photo is, but the second photo I see being used to put on the RS trim engine cover if you want to dish out for one. A lot of people ended up just using that as a mounting point for catch cans.
Anywho, welcome and hope you have fun doing maintenance and upgrades on your new car!
Old May 9, 2021 | 03:21 PM
JorbNorb's Avatar
CVT? Easy to change the CVT fluid. Drain and fill, 3.6 quarts. The CVT has a drain plug, a "fill" plug on the side of the transmission at the front of the car. If you have a long funnel or remove the airbox, there is a plug on top of the transmission you can remove and fill at.
Old May 9, 2021 | 05:52 PM
Thanks! Glad to know it isn't anything, I got a little worried!
Old May 9, 2021 | 05:56 PM
I've been watching an unhealthy amount of videos, and it does looks 'oil-change easy'! Thanks Jorb!
Dannie97
Aug 1, 2020 04:37 PM
hawkfitohio
May 28, 2018 09:58 AM
thebarber
Jul 21, 2012 09:17 PM
FiremanDon
Oct 27, 2009 06:36 PM
No_Skillz
Jan 23, 2009 03:09 PM
