Clutch kits
Old Dec 7, 2021 | 02:50 AM
Vechny's Avatar
Clutch kits
Hello.have a good day.is 2nd and 3rd gen clutch kits same?
Will 2010 clutch kit work for 2014?.cant find any info anywhere..thanks 😊
Old Dec 9, 2021 | 10:46 AM
Z062FIT's Avatar
Clutch kits are not the same. There are flywheel differences. That being said, if you order a 2G clutch kit and flywheel, it will work. Light weight flywheel will throw misfire codes and send your car into limp mode, which currently can't be tuned out with @KTuner like on the civic cars. Ask me how I know...
Old Dec 14, 2021 | 01:15 AM
BMWguy22's Avatar
Yes, it will fit
The clutch kits from the model years 2009-2019 are all the same (as noted on Rockauto)
You can choose from M-Pact, Luk, and Platinum Drive all have the same part number of 08061 for those model years.
And since they are the same, you can also select from Sachs K7058301 and Exedy HCK1010 as well.
Expensivehobby22
Oct 22, 2025 12:22 AM
clorbag
Aug 9, 2021 01:35 PM
Kevin Evans
Nov 18, 2016 04:23 PM
Cachupin
Jan 5, 2011 10:24 PM
YeeFit
May 9, 2009 09:34 PM
