What hardware do I need for the inner fender assembly?
I bought a used 2017 EX and it was apparently in a little fender bender at one point and the previous owner removed the splash shield and the inner fenders on the front. I found this post which has all the info I need for doing the splash shield but I am wondering if anyone knows what I will need to install the inner fenders? I am in New England where we use lots of salt on the road so I want to get these things installed to protect my car from rust as much as possible.
https://cimg8.ibsrv.net/gimg/www.fit...efc1f70b67.png |
I just lost a couple clips taking off my fender and replaced them. These are the following parts you need to assemble 1 fender liner:
90682-SEA-003 you will need 3 of these These are "square" push clips which are round on the outside and have a squared off bottom. These go into the square shaped holes. 91501-TRO-003 you will need 10 of these "standard" push clips. These push clips will go into the rest of the holes in the fender area. Screws. I don't have the part number. You need 2 screws in these locations. Screw #2 is located above Screw #1. Screw #2 is a bit hidden. Finally, you may need additional push clips and 1 more screw to attach the fender to the under side of the bumper. I'm not sure if any of that hardware is missing on your vehicle but be aware of that. https://cimg1.ibsrv.net/gimg/www.fit...fa4567702b.jpg https://cimg2.ibsrv.net/gimg/www.fit...92a783aab5.jpg https://cimg4.ibsrv.net/gimg/www.fit...5c41301f4f.jpg |
Thank you very much! The only hardware on it now is the screw that holds the bumper to the fender so this was incredibly helpful. I will get everything ordered and report back when the job is done.
Originally Posted by urs1ne
(Post 1480562)
