6MT guys, does your clutch pedal hit the floor?
Old Apr 21, 2015 | 01:49 PM
roksta's Avatar
I ordered some pedal covers and when installing them noticed the carpet under the clutch pedal was starting to wear. This is only with 2k miles.
Unfortunately for me I started with the gas pedal and noticed it when putting the clutch pedal on. I took it to the dealer and they blamed the aftermarket pedals. I had to go back later for the rear fender liners and I put the stock pedal cover on. They told me "Theres no way the rubber pedal will wear the carpet like that." even though it is very clear the pedal hits the carpet. They then told me that the other cars on the lot hit the floor too.
Just wanted to see if this is common or not on the GKs. This is my 7th manual car and I've never seen the pedal actually hit the floor instead of a stopper on the firewall.
Old Apr 21, 2015 | 09:21 PM
Stingray's Avatar
I never noticed. Will check and get back to you
Old Apr 21, 2015 | 09:43 PM
Uncle Gary's Avatar
I just looked at mine, and, yes, my clutch pedal also hits the floor. Hasn't hurt the carpet yet because I have Weathertech floor liners in the car, and the pedal hits the floor liner, and not the carpet.
I can't remember if this also happened in my '09 Fit. I guess I never paid any attention.
Old Apr 22, 2015 | 09:28 AM
Bassguitarist1985's Avatar
I too can confirm the pedal hits the floor, but the rubber show on the pedal isn't causing any major damage to the carpet, though there is a slight divot in there. I'll look closer at the clutch pedal arm and see if there is an extreme travel limit screw or something.
Old Apr 22, 2015 | 12:13 PM
Uncle Gary's Avatar
This is the 7th manual transmission car I've owned, but to be honest, I have no idea if any of them ever had a "stop" for the clutch pedal. It's just something I've never noticed in the 36 years I've driven manual transmission cars.
Old Apr 23, 2015 | 11:16 PM
Fit_as_a_butchers_dog's Avatar
Intriguing. I've owned 13 manual cars and the clutch has never had a stop that I knew of. They would I imagine all hit the floor. I'm guessing I only depress it enough to make the gear change, thus never making contact with the floor.
Old Apr 24, 2015 | 06:13 PM
roksta's Avatar
Here's the "stopper" on the firewall I was talking about:
It seems like the stock one is too mushy and gives too much when the clutch arm hits it. I had some rubber matt laying around thats about 1-2mm thick and thought I'd tuck it up there to try. It might be all in my head, but the car seems to shift smoother now and best of all the pedal doesn't hit the carpet anymore.
Old Apr 24, 2015 | 07:07 PM
Stingray's Avatar
Mine hits the floor, but no noticeable wear after 10K miles
Old Apr 24, 2015 | 08:53 PM
DrewE's Avatar
How do you guys start your cars? I know older manual cars didn't generally have a neutral starter "safety" switch, but for cars made in the last twenty or thirty years....
Old Apr 24, 2015 | 10:39 PM
MysTiC27's Avatar
I also have a small mark on the carpet. I have pedals diférentent I did not try again. For now I added a thin carpet.
[IMG]http://Name:  0vUvBSF.jpg
[IMG]http://Name:  Mh2RIrX.jpg
Old Apr 27, 2015 | 11:34 AM
Uncle Gary's Avatar
Not sure what you're asking. Most modern cars have an interlock requiring you to depress the clutch to allow the starter to engage. Most motorcycles, too, although my '93 Harley-Davidson doesn't. For a real thrill, hit the starter on a Harley big twin when it's in gear, and you forgot to pull in the clutch.
FTBT
Oct 14, 2019 08:41 PM
p1driftfiend
Jun 27, 2018 10:43 AM
evilchargerfan
May 2, 2018 09:37 PM
thric3r
Mar 2, 2011 09:50 PM
lovethatfit
Jun 4, 2006 10:20 AM
