How often does your TPMS go off?
You should try to pump in more than 32psi. The max on these tires are much higher than that so you don't need to worry if you have 3-5psi more in there. I usually run between 35psi. At 32psi you may be close to the lower limit of where the sensor light kicks in. Any changes in templates or road conditions can make the sensor think there is less air than there actually is. So adding more air for a buffer might sold your issues.
It's a Mickey Mouse system, but at least they got rid of the wheel sensors that tire dealers would "accidentally" break to add a bonus to your new tire bill.
Honda uses a special blend of 78% nitrogen, 21% oxygen, and 1% argon to fill tires at the factory.
rodney
Oct 4, 2014 01:13 PM
jelliotlevy
Jun 19, 2009 10:16 PM
