HKS silent Hi-Power Exhaust installed
Old 08-03-2015, 10:24 AM
Sam Tsai's Avatar
This was a test fit to find out if JDM HKS exhaust can be fitted on non L15B engine GK5 with CVT. The result was perfect fit, no modification required.
Car: Australian 2014 Honda Jazz VTI-L (GK5)
Engine: L15Z2
Transmission: CVT
Exhaust: HKS silent Hi-Power (Ordered from Japan)
Before and After
Sound Video
Old 08-03-2015, 11:36 AM
marcn24's Avatar
Will this fit the 2015?
Old 08-03-2015, 07:12 PM
Sam Tsai's Avatar
Yes, this will fit 2015.
Old 08-04-2015, 06:39 AM
GoBucky's Avatar
That has a nice low burble compared to stock. Doesn't sound tinny at all. Engine braking must sound a lot meaner now. Nice! Are you happy with the sound?
Old 08-04-2015, 08:44 AM
IamNabil's Avatar
I really like the way that sounds.
Old 08-04-2015, 10:12 AM
Sam Tsai's Avatar
Yes I'm happy with the sound so far, specially when doing engine braking.
Old 08-04-2015, 11:06 AM
IamNabil's Avatar
Hmmm. Is there a US source, and can I install it without a lift?
Old 08-04-2015, 07:16 PM
Sam Tsai's Avatar
Source was a problem for me here in Australia.
Hard to find one, or they have to special order from Japan with shocking price tag. So I order mine from Japan with perfectrun.jp
Or you can contact HKS USA?
To install it without lift. Jack the car up and place car stand, then you can start. Only require removing 2 bolts and 2 rubber mounts, then use them again on new exhaust.
Old 08-04-2015, 09:42 PM
jhn's Avatar
jhn
jhn is offline
I really like your car. Nice and clean and simple. As you probably already know, that color is not available in the States so it's always nice to see something different.
Those are my first choice in wheels, but I was impatient and settled on something else. I'll probably get them eventually for track use.
Car looks great!
Old 08-06-2015, 02:13 AM
doctordoom's Avatar
Supervillain
It's got that Spoon rolled tip look
Old 08-14-2015, 08:03 AM
Sean Chai's Avatar
hi.. like your wheels alot.. mind asking the size and offset? btw, might ask pr for quotation for this hks exhaust too..
Old 08-15-2015, 08:24 AM
Sam Tsai's Avatar
Wheels spec: Enkei RPF1 17x7 43
Tyre size: 205/45R17
Old 08-18-2015, 04:26 AM
.RYAN's Avatar
Have more pics of the wheel set up? I was going to go Kosei K1, but after talking to them directly it'll be awhile if ever before they will make a 17x7.5 +45 again. They need 80 pieces ordered.
Old 08-18-2015, 05:57 AM
Sam Tsai's Avatar
Here you go, but just be careful with copied wheels. Sometimes they end up(or worse) like the one in last picture.
Old 09-04-2015, 01:14 PM
2Rismo2's Avatar
What torque did you tighten the exhaust bolts? Also do you have any in car clips of the exhaust? I'm curious to hear what it sounds like in the cabin.
Old 09-06-2015, 02:21 AM
Sam Tsai's Avatar
It was installed by a Japanese mechanic, I'm not sure what torque did he tighten the 2 bolts. He use hand tools only, the HKS instruction manual did show 19.6~24.5 Nm (2.0~2.5kgfm).
I didn't take any in car clips, it will increase noise level in cabin for sure. But if you worry about noise in the cabin, changing exhaust is no recommended.
Old 09-06-2015, 11:12 AM
2Rismo2's Avatar
Thanks for the torque settings will help.
As far as the sound level, I'm not worried about the increase in decibel as this isn't my first exhaust. I want to make sure it isn't "buzzy". I don't want it sounding like a bee buzzing around. All the clips I've seen on the hks exhaust have been outside the car.
Old 09-07-2015, 11:29 AM
Sam Tsai's Avatar
I see, I do have this video link of a GK5 fitted with the same exhaust doing track driving. In car video, I hope you can see it.
20150614 ZIC Super Lap:CE-Racing GK5 ?? Time Attack.??????????????????
Old 09-08-2015, 07:28 AM
2Rismo2's Avatar
Thanks for the link but I can't get it to work, must use some crazy plug-in. I'll mess around with and see if I can get it to work.
Old 09-15-2015, 08:48 PM
yuffers's Avatar
Anyone know of any sellers in the states for this?
Quick Reply: HKS silent Hi-Power Exhaust installed
