Brake light condensation
Old Feb 7, 2016 | 04:03 PM
Vjaramillo's Avatar
Anyone else experiencing this?
It's happening in both.
Old Feb 7, 2016 | 04:36 PM
gderf's Avatar
I am seeing it in both back up light lenses.
Old Feb 7, 2016 | 08:51 PM
Vjaramillo's Avatar
I wonder if these can be replaced under warranty? I'll find out when I take it in for the door handle recall.
Old Feb 7, 2016 | 09:10 PM
gderf's Avatar
Let us know how that turns out.
According to the 2016 FIT manual on page 400, this is considered normal. So they may play that back to you instead of replacing them.
Old Feb 7, 2016 | 10:00 PM
Uncle Gary's Avatar
I had some in mine when it was new. It disappeared after driving it a while and it hasn't come back.
The owner's manual says a bit of this is "normal" but yours looks like more than I had. I'd see the dealer about it.
Old Feb 8, 2016 | 12:36 AM
Vjaramillo's Avatar
The owner's manual does say it's normal. Only if water starts to build up inside you should go to the dealer. Funny. Oh well.
Old Feb 10, 2016 | 02:46 AM
Nightime's Avatar
Its not normal there just covering there asses. I would take the tail light off and check that all the bulb are snapped in and tight. when I put my LED lights in they where not snapped in all the way from the factory
Old Feb 10, 2016 | 12:22 PM
Dick W's Avatar
Some amount of condensation is normal since the housings breathe and, when shutdown hot at night and full of hot and humid air, they draw in warm humid air as they cool. By next morning the warm humid air is cold humid air and condensed water.
Old Feb 11, 2016 | 12:12 PM
unless u have a spider living in there like my old subaru, then it's normal.
Old Feb 15, 2016 | 06:59 AM
Press Fit's Avatar
Yesterday I was mesmerized by the water in the backup light fixture of the CR-V driving ahead of me. The fixture was half full! I could see it slosh around as the CR-V turned and stopped. I would have loved to watch the driver backup so I could see if the bulb still worked.
Old Mar 26, 2019 | 08:33 PM
monkeydave's Avatar
what do you think about this back light on my 2018, i think the seal is bad from the factory as it is white and not black pressed together and the left light is ok and the seal is black.
it is only in the white area of the light, the red parts are all ok
there is two white marks on the lower left that seem to be condensation marks
it takes a week to clear and then it will start again, usually in sunny weather
only had the car two weeks, i hope they change it on warranty, but are photos alone ok as it might be clear when i get to the dealer
thanks
honestrands
Oct 15, 2021 10:53 AM
Fit4Jim
Dec 2, 2016 09:30 AM
InternDoc
Nov 3, 2011 06:36 PM
BIBIS
Jun 30, 2007 07:48 AM
Sera
Mar 19, 2007 12:22 AM
