3rd Gen DRL's
Hey there new to this forum and my fit. Was wondering how to disable the DRL's without pissing the rest of the car off? Anyone do this on the 3rd generation yet?
U pull #25 fuse in the fuse box under the dash to the left of the steering wheel. #25 only affects the DRL's.
Thank you very much
Originally Posted by mstr916
(Post 1347751)
disable the DRL's...
Originally Posted by Press Fit
(Post 1347771)
Why would you want to do this?
Originally Posted by KentFinn
(Post 1347776)
On the DRLs, I had the same question, why would you want to disable them?
Also, it is polite in some instances, to be able turn off lights. Ferry terminal & loading, parking in front of restaurants with windows facing parking lot etc,etc,etc.
So.....is it recommended to pull that fuse and run w/o the lights?
Advice appreciated. |
I recommend it. It takes all of 5 seconds, and then just run with your parking lights or headlights if you want lights on. It'll turn on your rear lights too.
I did it because I had HIDs in before, and it would cause a humming sound from the low input when my DRLs were on. Thus, I always had my headlights on, and I wanted to avoid any issues. But since I removed my HIDs, I just run with parking lights and it looks cooler, in my opinion. |
(Post 1347776)
Originally Posted by jtvisions
(Post 1347780)
I call this the "Drive-In movie feature". You can start the car and run the engine to work the heat or A/C without annoying anyone watching the movie. |
Originally Posted by Uncle Gary
(Post 1347809)
Some of us might be fitting the car with LED DRLs. In that case, we might want to disable the headlamp DRLs.
(Post 1347811)
You CAN start the Fit without the DRLs coming on, as long as the parking brake is engaged when you start the car.
Yes, as soon as you release the brake they will turn on.
Pulled the fuse. Accomplished my goal thank you. I hate DRL's is my number one reason for wanting them gone. I leave my lights in auto. Aaaaaand I ordered LED's for Hi/low and Fogs...
make sure you notify your insurer that you disabled the lights. it will affect your premium. you do not want to give the insurance company an excuse for not paying claims (I work for an insurance company). also bare in mind if you are in an accident the fact that you disabled the daytime running lights could be used against you in a civil law suit.
Thanks for the tips
(Post 1347760)
| All times are GMT -4. The time now is 10:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
