RV6 Catted downpipe test Fit Install... PIC Heavy!
Good evening everyone!
RV6 Catted downpipe arrived yesterday and installed Today 06/04/2017. Fit and Finish were top notch. No cracks in welds or missing pieces. Everything arrived perfect and installed smooth aside from my lack of preparation (I'm impatient). Tools needed for the Install... Short and long socket sizes - 10mm, 12mm, 14mm and 17mm 12" socket ext, 3" socket ext closed end/open end wrenches preferable (I don't have any lol) O2 Sensor socket ( bought at advance for $12) "Necessary" Phillips screwdriver Flat head or Plastic tab thingy (forgot what its called) to take out plastic tabs on splash guard towards back end. Difficulty on scale from a 1 (easy) to 5 (Pain in the arse) i would say a 3 if you have the tools but are unfamiliar and on the ground on your own. 2 with a Lift and air tools. https://cimg1.ibsrv.net/gimg/www.fit...8e7eda21fb.jpg Came packaged very well. https://cimg2.ibsrv.net/gimg/www.fit...871a2a1d97.jpg Shot from back to front https://cimg5.ibsrv.net/gimg/www.fit...525cfe53a5.jpg Up close https://cimg6.ibsrv.net/gimg/www.fit...5aac27f60f.jpg Hi-Flow Cat with RV6 badge. Looks proper! https://cimg7.ibsrv.net/gimg/www.fit...47566cd320.jpg Everything that came in the box! https://cimg1.ibsrv.net/gimg/www.fit...f6d1dd4071.jpg Why you need the O2 sensor socket https://cimg3.ibsrv.net/gimg/www.fit...deed50ebc1.jpg What the 1/4" O2 sensor socket looks like for those that have never seen one. $12 for the socket lol at Advance Auto parts. https://cimg5.ibsrv.net/gimg/www.fit...70530d7012.jpg once the socket is out, pull the heat shield off right from the top. https://cimg7.ibsrv.net/gimg/www.fit...56e11a6dbd.jpg top of the stock manifold. Ridiculously restrictive! https://cimg8.ibsrv.net/gimg/www.fit...ebce6c7bec.jpg Quick shot of my Hps Cold air intake and where the filter sits for those that are curious. https://cimg1.ibsrv.net/gimg/www.fit...ea001378cb.jpg custom exhaust. 2 1/2" all the way back. 2nd cat was already deleted previously. https://cimg3.ibsrv.net/gimg/www.fit...6e9ff0e452.jpg Why custom exhausts are sometimes NOT a good idea. This is why it took so long to install! I will be replacing soon. https://cimg5.ibsrv.net/gimg/www.fit...68f24c6ad6.jpg That bracket, among others also needs to come off. https://cimg7.ibsrv.net/gimg/www.fit...1058b1bdbf.jpg Stock Vs RV6. Huge difference. By far the best investment ever. https://cimg9.ibsrv.net/gimg/www.fit...9c5d960707.jpg Shot of the piece installed. Fitment is perfect. No issues at all and Install was so much easier... except of course for that 1 bolt due to my current exhaust. https://cimg1.ibsrv.net/gimg/www.fit...5b40d9bf3a.jpg EGR port. matched up perfect. Sound is up but my exhaust does NOT have a resonator at all and the stock Si muffler I'm running has over 100k miles on it so the packing is shot. Still, sounds great though. I like it for now. I'll be upgrading the exhaust soon. https://cimg4.ibsrv.net/gimg/www.fit...c12b7cc754.jpg RV6 DP from the top almost installed. link to sound clip |
First Impressions... Mid range is vastly Improved. Off idle part throttle is Def improved. Car feels a lot Peppier and pulls all the way to redline. Cruising is quiet at 60mph and really opens up the motor. Highly recommended. It makes a night and day difference. With a custom tune. This could be a great lil car!
Sounds good. Is your rear hatch garnish plasti dipped? How long did it take to get chipped like that. I just did mine and hope it holds up.
Nice detailed write-up. I wanna do this, but CA smog laws makes me think twice about it.
Originally Posted by first honda
(Post 1373175)
Originally Posted by Ryfle
(Post 1373176)
Any reason you went with the catted vs. the non?
Great looking piece, nice to see the aftermarket coming through!
I notice there is an oxygen sensor spacer placed pre-cat. Is there any reason for this? I have only ever needed them after a full cat removal or post cat (if it was an aftermarket high flow). Is it a space issue? |
Originally Posted by DannyJ7
(Post 1373257)
Originally Posted by ThadCastle
(Post 1373272)
Originally Posted by Twincammedfit
(Post 1373278)
I had already deleted the 2nd cat prior to installing the RV6 piece. The GK5 brings 2 cats. During the install, both oxygen sensors installed fine with no space issues. Did I understand you right?
Did the O2 sensor spacer come already installed on the header then? Or are you using it just as a precaution? Just asking because this seems like a great mod, I just don't want any hassles with NYS inspection. Have had great success with the spacers before though. |
(Post 1373301)
Is the O2 sensor spacer necessary if I install this into a stock GK5?
Did the O2 sensor spacer come already installed on the header then? Or are you using it just as a precaution? Just asking because this seems like a great mod, I just don't want any hassles with NYS inspection. Have had great success with the spacers before though. Oh... I just realized what you're talking about. It came already installed on the piece. Just screw in the sensor and you're good. I have had no CEL lights so far since the install. |
is there any drone on highway speeds, like 60mph?
Originally Posted by hydesg
(Post 1373945)
Nice install, too much mide to mid high range, sounds tinny. Fart can sounding. Performance in terms of letting the engine breathe better must be way better than stock though!
Originally Posted by Bassguitarist1985
(Post 1373951)
interested to see this down pipe with a stock exhaust. hoping the oem exhaust may tone down some of that fart can sound
does anyone else, have this downpipe installed and could share sound clips? |
(Post 1399123)
does anyone else, have this downpipe installed and could share sound clips? This is mine, but with Catless DP version + stock b-pipe + HKS cool style axle back exhaust. Not so loud in my opinion. I should have an in car cabin sample for the folks later. been meaning to make one. Cheers! |
those of you running the rv6 dp, did any of you get a tune for it?
(Post 1399123)
does anyone else, have this downpipe installed and could share sound clips? Ill have: -RV6 catted DP -BONE STOCK b-pipe -Tanabe Medallion axleback |
