Pulling 12V Power from Fuse Box?
I need to pull some power from my 2017 Fit EX to power a dash cam.
Thanks! |
Accessory 12V switched is a 7.5 amp fuse located in the fusebox under, and to the left of the steering wheel.
For 12V constant, I hooked that up to my sound system already installed, meaning I ran power wires through the firewall in the big, common wire bundle. The grommet is located under the steering wheel against the firewall. |
Pulling power from the fusebox would be a LOT more convenient. Isn't there at least one circuit with constant power?
I found a fuse slot with constant power in my 2015 Fit. See the images I posted in this thread:
https://www.fitfreak.net/forums/3rd-...ml#post1332962 |
not sure why youd need constant power for a dash cam. youre going to drain the battery if ran while parked.
id just tap a switched fuse and only use while engine is running |
