Should i be concerned about my coolant level?
Hi guys,
long story short,about six months ago, my 16gk engine started misfiring, took it to the dealership, they replaced my cat, spark plugs, gasket converter, fuel injector, fuel joint and a bunch of stuff.
Today was a somewhat cold day, -10 degree Celsius, feels like -17. I was topping up my wiper fluid and i realized the coolant level drop significantly. It was pretty much at the min line. I know for sure in august, i have top it to max line from my record book.
Should i be concerned and bring my car in again?
Holidays are coming up and i would rather not get stuck on the side of the road.
:S
:S
Just like air pressure in tires drops with the temperature, fluids also tend to shrink in volume with drop in temperature. This might be what you're seeing although the drop seems more drastic than can be explained by colder weather. Anyway, top it up a bit and check it frequently over the next while. Also look under the car for signs of an external leak.
Its also common for small coolant leaks to occur during very cold ambient temps. The coolant seeps out for a few minutes, but when everything warms up it stops.
You won't get stranded on the side of the road. But as mentioned, it's Good Practice to check the coolant level and keep it AT LEAST at the MINIMUM level.
PS, if the dealer/shop are nice guys, they might add coolant to your reservoir for free. It should only take a cup-full. It's normal for the level to require topping up a few drive cycles after any service where the system was opened. (This includes removing the air intake...Honda uses a coolant passage that warms the PCV a little)
theo.chan@gmail.com
10-19-2005 02:39 PM
