Wilwood on GK5
Who all has installed Wilwood brakes on your Fit? Post pictures for all to see
Originally Posted by bjosuesr
(Post 1394771)
Who all has installed Wildwood brakes on your Fit? Post pictures for all to see
no sir they are wildwood kit 140-10735
(Post 1394786)
I'm waiting on the mod to agree to my pics so they post
so auto correct got me. they are WILWOOD part number 140-10735-DR
(Post 1394799)
What made you opt for the six-piston calipers over the four-piston calipers? |
Originally Posted by USDM
(Post 1394801)
I approved your post. :thumbups:
I'm normally a fan of bigger brakes, but without doing some kind of rear disc conversion, you're taking a setup that already has a huge bias to the front and making it even more biased to the front. I know the fronts do most of the work, but on this car with the drums and most owners not trying to late brake into corner entry, my suspicion is that they intentionally reduced the rear braking power to increase the service interval.
I don't have any numbers to prove it one way or the other, but I've seen on other threads that people go three or more sets of front pads before the drums need any work. Other family cars I've had were either two to one front/rear, or change all four corners at once. |
I agree with the 60/40 split front and rear and the fact that the fronts wear quicker than the rear. Every vehicle I have ever had I have put more brake pads on the front than the rear usually two to one as you say, it just depends on your driving style. |
I also read a couple other forms about the GK5 DPHA Wilwood set on a track GK5 out of China and he posted that this setup wasn’t much better than stock but that the 12 inch rotor was a noticeable difference. Both kits he tried he had race shoes installed on the rear for the drums. He also stated that he had driven other GK5s that had the rear disc conversion and didn’t notice any difference then his car with the race shoes on the rear drum setup |
Originally Posted by kenchan
(Post 1394788)
Originally Posted by Amabento
(Post 1394857)
OCD wouldn’t allow me not mentioning the H isn’t aligned with the stem. Sorry. Set looks good. |
Nice! I want kne myself, but i thought the pn /n for the fits is 140-13029? whats the difference? also what rotors are you running in these? |
Originally Posted by Exgk5
(Post 1395636)
Nice! I want kne myself, but i thought the pn /n for the fits is 140-13029? whats the difference? also what rotors are you running in these? Wilwood High Performance Disc Brakes - Front Brake Kit Product Number: 140-13029-R The brake calipers you are seeing in the photos above my post are Wilwood's six-piston calipers. Wilwood High Performance Disc Brakes - 2013 Honda Fit EX - Front Brake Kit No.: 140-10735-DR |
Thanks for replying USDM. The rotors come in the kit as USDM mentioned. They are the SRP drilled rotor. Here is a pic from Wilwoods website with part numbers.https://cimg9.ibsrv.net/gimg/www.fit...9eabfa3ab1.png |
(Post 1395643)
