2015 Honda Fit Key Fob
Old Mar 24, 2018 | 05:19 PM
Exgk5's Avatar
After i cleaned Brad this morning, i parked in the garage and went to eat, now im going to start the car and it wont start!
I tried pushing the start button with the key fob and it started!!
However, the smart entry key indicator light is on, and the car won’t start if i don’t put the key fob close to the push button.
Also, the car won’t unlock anymore if im only close to the door, i had to use the key fob to unlock and lock the doors.
any suggestions on why its doing it? I don’t want to put the key fob close to the push button everytime.
appreciate the response..
Old Mar 24, 2018 | 05:28 PM
just get a new lithium battery for your fob. i had to replace mine a few months ago.
Old Mar 24, 2018 | 05:32 PM
Old Mar 24, 2018 | 06:38 PM
Exgk5's Avatar
Thanks kenchan for the response but i just got a new battery today and replaced the old one and still the same... the car starts as long as i put the key fob close to the push button. But i dont want to have the light on all the time and keep doing it...
Old Mar 24, 2018 | 07:26 PM
huh, sounds like the RF receiver is damaged or intermittent.. is your car still under warranty? id take it to the dealer in this case.
Old Mar 24, 2018 | 07:45 PM
Exgk5's Avatar
whats the RF receiver? Oh and no i lost the warranty last year...
Old Mar 24, 2018 | 07:46 PM
Exgk5's Avatar
Old Mar 24, 2018 | 07:50 PM
woof's Avatar
Did you try your other fob to see if it works OK?
Old Mar 24, 2018 | 08:05 PM
Exgk5's Avatar
Yes i did, i change both batteries to new one as well. But still the same.. i reset the car battery too and no change..
Old Mar 24, 2018 | 10:43 PM
Razor_Burn's Avatar
It's rare, but the new battery could be dead. If you have a multimeter check the new battery and make sure it is more than 2.8V.
The keyless entry/smart start is on fuse 25 in the box under the hood near the strut tower. It's listed as a 7.5 amp fuse.
Another possibility is that on of the connectors going to an RF receiver/transmitter for the keyless entry system got disconnected or bumped in such a way that it no longer makes solid contact. There is one in the trunk where the spare tire is held. I'm not sure how many more there are or where they are, but they keep track of the keys location (inside or outside of the car), and allow the keyless system to work.
Along the same lines there is the possibility of mice or other rodents chewing through electrical cables. It's a nightmare when they do this, but apparently they find the soy based coating quite tasty. So if you've reached this point I would look at the air filters (intake and cabin) to see if they have taken material for a nest indicating they've been in there.
Edit:
They're is another fuse for the smart entry system in the drivers foot well. It's number 3 and listed as a 10 amp. Fuse locations and descriptions are shown on pages 423 & 425 of the user's manual.
Old Mar 25, 2018 | 10:47 AM
Exgk5's Avatar
Edit:
never thought to check the fuse and wiring. I will definitely check on that today.. thanks for this i really apprieciate it! Will update everyone once i checked all this.
Old Mar 25, 2018 | 11:28 AM
the fob transmits radio frequency codes and there is a receiver on the car side that reads them to identify the key. my guess is that there is something wrong or interfering with the receiver since you can still start the car when you move the receiver very close to it. if the receiver was dead then you wont be able to start the car. did you recently do any stereo or electronic installs on your car?
sucks on the warranty.
Old Mar 25, 2018 | 02:03 PM
Razor_Burn's Avatar
From my understanding there are two methods in which the car can receive the authorization to start. The primary one is that the key has power and actively transmits allowing the position of the key(inside of the car) to be known and authorizing the starting of the car based upon the codes the car receives. The secondary system is for when the key has no power of its own it functions as an RFID device and receives power from a electromagnetic field near the start button to function and transmit the codes to start the car.
So if the OP has a good battery in his key then his car is relying on the secondary method of authentication to start. This means that something in the primary method of locating or receiving the signal from his key is failed.
On 2013 accords there was a TSB for a similar problem to this that required replacement of the Smart System PCU and a reprogramming of the FOBs.
Old Mar 25, 2018 | 04:49 PM
makes sense to have redundancy.
Old Mar 26, 2018 | 10:01 PM
Exgk5's Avatar
UPDATE:
It’s back to normal again!!! So after work i opened up the panels uner the steering, the panel under the ac with the hdmi and lighter are located and turns out one of the connectors was loose. So i snapped it back on and tighten all the connectors i can see. And put the battery back on and pray it was just that. And thats it!! Started back to normal again..
Thanks guys for all the help and taking time responding and helping a brother out. I really appreciate it!!!!
Thanks again!! BRAD is back!!
Old Mar 27, 2018 | 07:16 AM
2Rismo2's Avatar
How do you think that connector got loose?
Old Mar 27, 2018 | 07:58 PM
sounds good op! GJ fixing it.
Old Mar 29, 2018 | 04:49 PM
Exgk5's Avatar
i think it was when i remove the whole panel before when i installed by shift boot collar. I guess i didnt get to snap it back in.
Old Mar 29, 2018 | 05:05 PM
bosho.777's Avatar
I installed my stereo system in my Fit last year and attempted to go for a test drive without the accessory socket/HDMI/USB panel plugged in. The car would not start and I had to re-trace everything I did during my stereo installation to determine if I missed something or caused a short somewhere. 4 hours later, I decided to plug the accessory socket/HDMI/USB panel back up and was going to call for a flat bed truck to tow my car to the Honda dealership, but the car started!
It's amazing how something as simple as an accessory socket/HDMI/USB panel can cause such a major headache. I'm glad you figured out your problem.
Old Apr 6, 2018 | 11:30 AM
Exgk5's Avatar
i know!! It gets frustrating but then when you figured it all out you just move your head sideways. Lol
I’m thankful its just that and nothing major..
