OBD not connecting
So some animal chewed the wires on my O2 sensor (anyone else have this problem?)... so it shorted out.
CEL! That I can fix - however now OBD will not connect. I'm thinking a fuse? Though I think everything else works.... Can someone give me a hint about which of the hundred fuses to start testing? (2016 Fit) (or have an alternative theory?) |
If scanner won't power up it might be missing power for the OBD2 data link connector,
Check the "back up" fuse in the engine compartment box #B29, 10A If scanner powers up but cannot communicate with the PCM, you might be in a deeper mess |
