3rd Gen GK Specific Fit Engine Modifications, Motor Swaps, ECU Tuning Sub-Forum Threads discussing engine mods/swaps/tuning for the third generation GK Honda Fit.
aFe Takeda Intake
Old Jul 20, 2018 | 09:53 PM
vinylengraver's Avatar
aFe Takeda Intake
Now that the exhaust is taken care of, I think I need this:
https://afepower.com/afe-power-56-70...-intake-system
Opinions?
Old Jul 20, 2018 | 10:19 PM
xxryu139xx's Avatar
now that's nice.
Old Jul 20, 2018 | 10:26 PM
xxryu139xx's Avatar
best design i've seen. i'm about to preorder the one u linked.
Old Jul 20, 2018 | 11:00 PM
Alfa38's Avatar
Interesting. Looks like a good design.
Old Jul 21, 2018 | 10:54 AM
2Rismo2's Avatar
Oh that looks nice!
Old Jul 21, 2018 | 11:41 AM
+5 HP / +7 lbs. x ft. Torque max gainz.. da amish would be very jelly.
Old Jul 21, 2018 | 03:00 PM
hasdrubal's Avatar
Two thoughts on this piece. First, I really hope someone does before/after dyno testing. Advertising hp/tq numbers without one makes me suspect their marketing guys just guessed what it might do. Second, what is the hole at the back for?
Edit- I know there's a chance the stock airbox has something on it to explain the hole in the back, but if someone here already knows it saves me a half hour getting the kids situated before going to look.
Old Jul 21, 2018 | 08:31 PM
xxryu139xx's Avatar
well i guess that's where its getting more airflow from. the stock airbox only has the front to draw air from.
Old Jul 21, 2018 | 09:10 PM
hasdrubal's Avatar
I would think it gets more airflow by having more surface area on the filter, and smoothing out the path from the end of the intake tract. Having an opening inside the engine bay makes it not much different from all the short ram setups, drawing hot air in.
Old Jul 21, 2018 | 09:36 PM
Hairymonkey019's Avatar
I think that's where the stock resonator goes to
Old Jul 21, 2018 | 09:48 PM
Cichlid_visuals's Avatar
This is an interesting set up, the opening in the back is probably there to increase throttle response at low RPMs like a short ram intake would, and the fact that it still mounts up to the front duct means that at speed you'll draw in cool air like the stock system does, so it's the best of both worlds with overall larger flowing diameter. What confuses me is that it still hooks up to the stock resonator, i would have done away with that altogether. This would be good combined with one of those ram air ducts a few members have here.
Old Jul 22, 2018 | 10:59 PM
2Rismo2's Avatar
What's stopping someone from cutting a hole in the rear of the stock air box to have a similar design? Maybe connected to a tube a little lower in the engine bay?
Old Jul 23, 2018 | 12:13 PM
evilchargerfan's Avatar
Hairymonkey019 sure as hell did that ... he cut a hole in the bottom of his stock air box
https://www.fitfreak.net/forums/3rd-...duct-10-a.html
Old Jul 23, 2018 | 12:16 PM
elkaku's Avatar
The great question is .... did it do the job....
Old Jul 23, 2018 | 02:14 PM
by doing the job .... I'm assuming you mean like, results/HP gains.... Takeda never posted dyno results so .... like someone else already said, these are all just "claims" at this point. and I believe in the youtube video, he mentions there is probably no real gains/he did it so it sounds cool or something along those lines
or.... if you meant .... was hairymonkey able to achieve the same effect as the takeda and increase CFM's .... heck yes .... he has tons of air flow now!
Old Jul 23, 2018 | 02:34 PM
elkaku's Avatar
Thanx Evil.... i just saw the vid completly and heard him say it was more for the sound, but he does have a pretty strong point when stating that if any major manufacturer can claim hp and tq gains with systems that are basically what he did, then he COULD be onto something...
Old Jul 23, 2018 | 02:43 PM
I'm considering doing this mod to my stock intake box as well. If I do and happen to notice gains (using my butt dyno), I'll report back
Old Jul 23, 2018 | 07:39 PM
Before u guys go copying that video, know you will increase you intake temps by 40+ degrees and will Definetly lose power. Our transmissions put off alot of heat, cutting the bottom of the box is sucking air from directly over the transmission, during my testing i recorded an increase of 40+ degrees Fahrenheit. Also makes keeping the front cool air duct pointless, air will come through the path of least resistance, if you cut a huge hole in your airbox, it will completely bypass the cool air duct in front, making it dead weight. Aem is the only one so far to show an actual dyno video with increase in power with their intake, and even it still increased intake temps over stock.
Old Jul 24, 2018 | 08:21 PM
xxryu139xx's Avatar
I emailed aFe regarding release date. They said ship date will be 7/31. I guess I am getting this sooner than expected.
Old Jul 24, 2018 | 10:16 PM
knope's Avatar
the price is a bit steep, however it looks like a solid upgrade. the shroud should keep water out, which is a general concern of mine with any aftermarket filter.
please update after it's installed and put through a good rain storm.
