Rear Wiper "Repair"
Old Nov 18, 2019 | 02:57 PM
SilverEX15's Avatar
Rear Wiper "Repair"
My son, with a 2019 Fit EX, came home today and said his rear wiper wasn't wiping. It was just hanging down. I removed the plastic cover over the 10 mm attaching nut, and I saw that the nut was just a few revolutions away from coming off completely. I tightened it and put the plastic cap back on. When was the last time you saw the nut that holds a wiper come loose? For me, it's never.
It might not be a bad idea to check the tightness of that nut on your Fit. My son's car had metal shavings on the body from the shaft turning inside the wiper arm. Be careful removing that plastic cap. I think the best way to remove it is to pull out both sides of the skirts that hang down from the top of the wiper. I tried prying it, and I broke a small piece off the top.
Old Nov 18, 2019 | 03:06 PM
Jazu's Avatar
Never on my 17 year old CRV (just sold) and my recently sold 1992 Integra and my old (and stolen) 1994 Civic VX. That's modern Honda quality with a capital Z.
I'll put that on the list of items for the dealer to fix on my 2019 (including door sag, coolant below MIN line, etc).
Old Nov 18, 2019 | 06:39 PM
GolNat's Avatar
Well they are no long made in Japan.
Same is happening with other brands as well.
Old Nov 18, 2019 | 07:38 PM
2Rismo2's Avatar
MDM (Mexican Domestico Mercado) wiper mod
Old Nov 19, 2019 | 07:40 AM
Jazu's Avatar
How much wiper play is there if the locking nut is tightened properly?
Old Nov 19, 2019 | 09:36 AM
SilverEX15's Avatar
In this case, the wiper was hanging straight down. If it's loose enough to let the shaft slip in the wiper, it will grind away the grooves that should be keeping the wiper engaged with the shaft. So, basically, it will be fine if the nut isn't tight, until the wiper starts drifting off the shaft.
Old Nov 19, 2019 | 11:54 AM
evilchargerfan's Avatar
perhaps your son was attempting to do the wiper delete mod. all the cool kids are doing it
Old Nov 19, 2019 | 11:57 AM
SilverEX15's Avatar
Yeah. He decided to remove the wiper so he could have a nice coating of snow on the rear window, but he stopped after loosening the nut. He figured he'd go back and remove the nut and the blade later.
Old Nov 25, 2019 | 12:45 PM
nomenclator's Avatar
Yes, to remove the plastic cap one can just spread the sides apart with fingers and pull the cap off, left forefinger on one side, right forefinger on the other side. The sides are very easy to spread apart; no tools are required. I thought it was odd that the whole thing comes off. My Toyota's rear wiper cap stayed attached at one end and rotated out of the way, rather than came off completely. Don't remember how it was attached. Probably just a pin passing through it and the wiper arm that it wrapped around.
Old Feb 24, 2021 | 09:06 AM
Bev Stanton's Avatar
Thank you!!!
Thank you for posting this! my 2019 EX had the same issue after an ice storm and I just needed to tighten the bolt.
Old Feb 24, 2021 | 09:59 AM
SilverEX15's Avatar
Glad I could help.
Old Feb 24, 2021 | 04:28 PM
Jazu's Avatar
I wonder if that's where the ticking sound is coming from - especially when the car's rear end faces the sun on very cold days. I've not been able to isolate where the expansion is coming from but a realtively new car shouldn't have that nut backing out. But extreme temperature differences and the sun's radiant energy might be playing with the stressed connection between the nut/bolt and the glass all expanding a different rates.
Old Feb 21, 2022 | 06:43 PM
mfagerburg's Avatar
Smile Thanks for the help!
The info to pull the cap on both sides was a great help for me- the wiper on our 2019 Honda Fit had also come loose. Tightened it up and it works great! Thanks!
Old Feb 21, 2022 | 08:15 PM
Action Jackson's Avatar
I would love to reposition the whole assembly so that it pivots from above like some Toyota and Lexus vehicles. It would probably be less prone to heavy snow build up, but probably a better view out rear b/c of the wiper pattern being more cleared at the top.
Old Feb 21, 2022 | 08:54 PM
mfagerburg's Avatar
Old Feb 22, 2022 | 08:27 AM
SilverEX15's Avatar
"...heavy snow build up..." I see you're in Canada.
kkim
Jan 9, 2025 02:36 PM
Flashesbuck
Jan 4, 2023 11:33 AM
rjm161
Apr 27, 2022 08:44 PM
jt.wilson89
21
Nov 8, 2015 10:01 PM
codenamezero
Mar 3, 2011 10:00 AM
