Guess you do need to change plugs...
Old Nov 29, 2019 | 03:59 PM
robs's Avatar
At 120k miles. They're in order of 1 to 4... Plug 3 was pretty ate up.. the others weren't that good either.
Easy to change, IF you have the right tools... 14mm deep well with 3" extension and two 2" extensions.. Put on the 3" extension and lower in the hole add 2" extensions as you go!
There was some rust on the coil boots from the steel liner. I added some dielectric to the seal to help out...
VelvetB
May 11, 2016 06:59 PM
noelrobles22@gmail.com
Jan 21, 2016 09:00 AM
wackyflik
Oct 4, 2014 09:11 AM
Donatib
Nov 27, 2011 03:54 PM
Papparock
Nov 16, 2009 02:23 PM
