Starter button
Old Jan 20, 2020 | 12:30 PM
Rob1965's Avatar
Starter button
Need to replace the starter button on my 2016 jazz/fit just wandering if anyone has done this themselves and what's involved in getting to the rear of it to depress the two retaining clips
Old Jan 24, 2020 | 10:42 AM
16FlaFit's Avatar
If you take the trim panel that goes around and under the steering off, you'll see an opening next to the switch.
Get a zip tie, and bend it so it has a curved shape. Feed that zip tie around the switch and tighten it when it's over the tabs. Push the tab you can see, with your finger while tightening the zip tie (it'll press the other tab).
At that point you can work the switch out of the dash. along the way you pull the cable out the back.
Install by sliding the switch partly in, plugging in the cable, and then pushing the switch in the rest of the way.
Old Jan 24, 2020 | 02:37 PM
Rob1965's Avatar
Thanks for the reply. Found a thread which showed you having to take half the dashboard apart and was not looking forward to doing that.
Bmcqueen
Nov 11, 2024 11:06 PM
goblazers
Jan 6, 2021 08:20 PM
doctor J
Sep 30, 2019 12:02 PM
mumblecrust
Feb 15, 2019 09:07 PM
SevereService
Jun 25, 2014 08:02 PM
