Quality Issues with new Fit
Old Oct 28, 2014 | 11:48 AM
  #281
kenji815's Avatar
Originally Posted by trashercan
Gents / Ladies... I am interested in two models (one yet to arrive) up here (Both EX MT) and their VIN numbers / manufacture dates are as follows:
26 Sept 14 with the VIN 102800
8 Oct 14 with the VIN 103706
Does the number at the end e.g. 102864 and 103708 show the production order ? all other comments I have seen here the max VIN number seems to be 30,000 - these are in the 100,000
yes last series of digit is serial marking of it's # off production line.
Old Oct 28, 2014 | 11:53 AM
  #282
trashercan's Avatar
Ok so - for VIN's above the 100,000
ie 100,000 vehicles and above off the production line (does that sound like a reasonable number since start if manufacturing ?) has anyone been seeing the quality issues like the previous earlier models or have the Japanese execs fixed the problems.
I am so very close to committing to one of these models up here (the one I want comes in next week) I am still on the fence. I have a 2007 GD1 and I am totally happy with the build quality I dont know what to do..
Old Oct 28, 2014 | 11:54 AM
  #283
Fitmo's Avatar
My August built one (US model) ends with FM7246XX but I doubt that means nearly 3/4 of a million.
Old Oct 28, 2014 | 02:04 PM
  #284
misterkyu's Avatar
Wow, I'm really surprised about all these issues that the 2015 Fits are having... Although I really wanted the 2015, should I be glad that we got the 2013 instead?
We had our 2013 Fit since March this year (almost 8 months old now) and the only problems that we had was a dead battery (since we left the headlights on for an hour) that was covered under warranty and the loose Honda emblem on the hood that was replaced under warranty as well. But there are some window rattles on rough roads.
My 2013 Accord did have a paint defect on the right side taillights that was covered under warranty, so I'm guessing a lot of Hondas are having paint defects these days...
Old Oct 28, 2014 | 02:31 PM
  #285
GeorgeL's Avatar
I believe that only the last five digits are sequential. The "100,000" digit seems to jump around and is a "plant identifier" or "market identifier" in some VIN schemes. It seems to be "8" for Canadian Hondas, for example.
At this point production seems to be somewhere between 25,000 and 30,000
Old Oct 30, 2014 | 10:29 PM
  #286
mahout's Avatar
I am sorry to laugh at your misfortune, that is just terrible.
To be fair to Honda my built in Japan 2010 has none of those problems with 100k miles. I think you just happened to come back when Honda just opened a new plant in Mexico with new workers on a newly designed car.
There will be no QC problems they said. It'll be fun they said.
The quality problems are now full blown. Not only assembly problems galore but also Honda, , BMW, Ford, Nissamn, Mazda, Chrysler, and Toyota all use Takata airbags tho which models not identified last June. In late June Honda began national recall of certain models; if you haven't got a notice by now your Fit probably doesn't have Takata airbags. NHTSA is getting a real black eye this time.
Old Oct 31, 2014 | 04:32 PM
  #287
Wanderer.'s Avatar
I wasn't aware of that mahout, thanks. No, I haven't gotten any notices and I check occasionally for TSBs and mine has yet to be effected by any of them.
Old Nov 1, 2014 | 08:38 AM
  #288
exl500's Avatar
It means 24,6XXth 2015 Fit. Don't ask what happens when they hit 100,000.
Old Nov 1, 2014 | 07:21 PM
  #289
Gregg's Avatar
At the rate they are building them, they will not get to 50,000 for the 2015 model year.
So not to worry, what happens when they hit 99,999.
Gregg
Old Nov 3, 2014 | 01:47 PM
  #290
stellgod's Avatar
Had a problem this weekend. Pulled into a parking lot, and tried to roll up my window. Window sounded like it was off it's track, and would NOT roll up. I had to help it up with my hand.
Went into the store, came back out, no more problems.
Also, does anyone know how to remove those freakin spots on the window? I have 4 large round spots on my window which I assume is from the factory where they held the glass on those suction cups, and it won't come off with regular scrubbing.
Also again, I changed the time on my clock yesterday, and somehow managed to delete my wallpaper. Maybe I'm an idiot, but I don't remember going into that screen.
Old Nov 3, 2014 | 02:01 PM
  #291
Popeye's Avatar
Try toothpaste and a microfiber cloth and lots of lukewarm water. Toothpaste has a real fine abrasive; just make sure you have a steady stream of water
Old Nov 5, 2014 | 12:47 PM
  #292
Bigbadvoodooguru's Avatar
Hello all, since I've owned the car I've washed it more than a dozen times, and there was alway a little bit of water on the passenger side front door, on the inside. I dismissed it as a bad design and the water must have ran into the car when the door was opened.
Couple that, with all my misaligned doors, and the fact that none of my doors close properly with adequate closing momentum. Meaning, I constantly close my door, and it doesnt close all the way, and I have to reopen and close the door again, especially the passenger side doors. I don't have this problem with other vehicles. Anyways, since the rear passenger door sticks out on the bottom, and sticks too far in on the top, I dismissed the front door sticking out too far at the top and too far in the bottom.
Well after we got some rain on Halloween, I noticed there was significant water on the inside of the front passenger door. Upon futher inspection...
The rubber weatherstripping on that door is completely squashed and deformed, and water leaks through into the vehicle.
This was NOT one of the pieces of weatherstripping that fell off the vehicle when I opened the door originally (and was warped to begin with). Those pieces are the interior pieces, as can be seen in the pictures. Coupled with my misaligned doors the door leaks.
I guess I'll be going back to Honda. AGAIN. The wife won't let me sell the car at such a big loss
Also, getting a nice big clunk from the rear when coming to a complete stop a little faster than I normally would. Sounds like a spring unloading, then binding when the vehicle settles again.
Old Nov 5, 2014 | 12:57 PM
  #293
pjaymac's Avatar
You would seem to be a prime candidate for lemon-law reimbursement. It's really shocking that such defects are being found on a Honda. Sure doesn't bode well for the vehicles being manufactured at the Celaya plant, whether they are Fits or HR-Vs or whatever.
At the rate of all the defects in the '15 Fit, who will buy the first year of U.S.-released HR-Vs? Good luck to all of those people!
Old Nov 5, 2014 | 01:26 PM
  #294
DArkk's Avatar
Earlier run did have problems which is why Honda stopped production for awhile to get them sorted out. I got my Fit in Oct (built in Aug) and didn't have these kind of issues.
Last edited by DArkk; Nov 5, 2014 at 06:42 PM. Reason: Wrong month when I got the car. Opps
Old Nov 5, 2014 | 01:31 PM
  #295
pjaymac's Avatar
That's good, DArkk.
Old Nov 5, 2014 | 02:32 PM
  #296
exl500's Avatar
Absolutely lemon law. From this forum alone we can see that some people have had minor issues, but the vast majority are perfectly pleased. Yours is ludicrous.
Old Nov 5, 2014 | 02:59 PM
  #297
Yes I guess I'll have to look into lemon law... the last two Honda's in the family that were lemon lawed was a pain... had to fight for a year on one of them :/
Old Nov 5, 2014 | 03:14 PM
  #298
jinw's Avatar
Scared to buy a honda
Old Nov 5, 2014 | 03:33 PM
  #299
pjaymac's Avatar
The fact that you have had to pursue lemon-law remedies for two Hondas is astounding!
Old Nov 5, 2014 | 03:34 PM
  #300
Fitmo's Avatar
In my experience and others I've known, when you buy a Honda or a Yamaha product, the probability of getting an impeccable product is about as high can be had... or said another way, the probability of having a problem is about as low as you can get. The trade-off is God help you if you have a problem... you are screwed... their customer service will make excuses and go as far accusing you of negligence--certainly nothing can be wrong with their product. Now they have Internet forum reps trying to do damage control, but it all breaks down because their customer service really hasn't changed.
This isn't my first Honda vehicle... I've had Honda lawn mowers, Honda generators, a Honda motorcycle, and a buddy has a Honda outboard. I'll keep buying them because the odds are in my favor. I've seen the same from Yamaha.
BTW, Honda, I'm going to keep telling this over and over on this forum until you fix the problems from the early adopters of 2015 Fits, such as the fender liners, etc.
