Brake Pedal Flutter?
Old Sep 22, 2015 | 09:34 PM
esnave09's Avatar
I've noticed recently that when I first start pressing my brake pedal that there is a slight shudder to it when the brakes first engage. I've never noticed it before, but it's only for the first 1/4 inch of travel or so and braking still seems to be solid enough.
Anyone else experience this at all? And should it be something I should bring it into the dealer for? It doesn't seem to be an urgent issue yet, but in the near future if it gets worse I'll make an appointment.
Old Sep 22, 2015 | 09:43 PM
exl500's Avatar
Sorry, no.
Old Sep 23, 2015 | 09:27 AM
Carbuff2's Avatar
Has your Fit seen it's first winter yet?
If so, the rotors may be building up a bit of rust on the edges (from the road salt).
If no winter yet, you MAY be experiencing some brake pad redeposit? The way to prevent that is to keep the car moving after a harder stop (at the end of a freeway exit ramp, for example). Just stop a car length or two back of the vehicle ahead of you, and creep...
-Warped- Brake Disc and Other Myths
Old Sep 28, 2015 | 02:00 PM
esnave09's Avatar
It did go through last winter. And it wouldn't surprise me if that was the case, since they use the harsh slat brine stuff here.
Old Sep 28, 2015 | 06:05 PM
Hitman1614's Avatar
omg yes this started happening to me it started right after the last time i had the oil changed on the car not sure if they did anything but brakes were perfect now when i press them i feel the shudder. i have 16k miles on it.
Old Oct 9, 2015 | 04:46 AM
Nightime's Avatar
Happen to me once. I had just gotten in my car and drove 2 blocks down and I hit the brake and the peddle was supper stiff. After I let off and reapplied brakes and it worked fine. I just assumed it happen because I had just turned my car on and there wasn't enough vacuum pressure in the booster yet.
jfw432
May 25, 2019 08:04 AM
Gk5baby
Jan 6, 2017 07:29 PM
Thismightnotfit
Jun 2, 2012 05:05 PM
Ein
Nov 30, 2008 02:44 PM
DavidB
May 4, 2005 11:16 AM
