Additional fixes for coilpack misfires worked
Old Jan 8, 2016 | 11:23 AM
Stingray's Avatar
After the coilpack recall, mine still misfired sporadically. Honda told dealer to put new injectors in, and adjust valves. Got it back and runs smooth as silk. Not a hint of misfire, and mpg went up by 2.
Old Jan 8, 2016 | 11:39 AM
dwtaylorpdx's Avatar
I'm betting it was the valve adjust.. Unless they had a run of really bad injectors.. Makes ya wonder...
Old Jan 8, 2016 | 01:20 PM
Stingray's Avatar
Hasn't been long enough to know if the fix will continue to work, but right now I am happy with it. Honda told them to do both. Would be nice to know which one worked.
Old Jan 8, 2016 | 01:30 PM
tmfit's Avatar
Was this a misfire while at speed or a stumble on take off?
Old Jan 8, 2016 | 05:04 PM
Stingray's Avatar
On take off
Old Jan 19, 2016 | 09:12 AM
noelrobles22@gmail.com's Avatar
If you need a valve adjustment can that cause a cel and cylinder misfire?
Old Jan 19, 2016 | 09:13 AM
I'm trying to figure out what's going on with mine I changed all 4 coils and plugs but cel came back and idle at cold start seems rough
4d_POWER
63
Jan 9, 2020 08:23 AM
angus.mundy
May 17, 2018 11:45 AM
fittenmittens
Sep 2, 2016 06:40 PM
hollyh
Mar 11, 2016 10:43 PM
blackbetty09
Aug 7, 2014 09:58 AM
