2015 Fits prepare now for larger battery
SInce my original 51R Fit battery is almost 4 years old I know it will need to be replaced. My 2015 has the so called smaller battery tray that will not take the larger 151R battery without a mod. I decided to do the battery tray mod now so it will be ready when I go to larger battery. Newer fits will take the 151R with no modifications to the tray. I took out my tray and cut off the end so the larger battery will drop in when I need it. Best to be prepared. Picture is of cut off part off my battery tray.
https://cimg4.ibsrv.net/gimg/www.fit...0fe3c91a37.jpg |
you have your battery model numbers backwards. the larger battery is the 51r. the smaller battery is the 151r, which is stock to the fit.
Thanks for correction.
James |
I did replace my 151r original battery with 51r couple weeks ago. I don't think is necessary cut under tray just simply remove it. Is there just to collect dust water and debris anyway We already had few "real" winter frost and I really appreciate bigger cold starting power of 51r
