Where to find plastic pins for engine under cover?
2018 Fit EX. I ran over some frozen manure and did some minor damage to the undercarriage protection. I believe I am missing the two rearmost push pins for the plastic under cover. The rest of the cover is held on with screws but I think the rear is held on with push pins. Anyone know where I can find these?
Thanks. |
Originally Posted by Nord-Est
(Post 1421399)
Thanks. https://www.fitfreak.net/forums/3rd-generation-2015/94227-splash-shield-screws-retainer-clips.html |
Answering my own question. OEM P/N:
91514-TG1-T01 https://www.fitfreak.net/forums/3rd-...ner-clips.html |
Originally Posted by JerBear716
(Post 1421400)
This should help:
imo, the oem retainer clip sucks. I use something like THIS:
https://cimg0.ibsrv.net/gimg/www.fit...1d09cd2041.jpg (its beefy, once its in there, its NOT going anywhere. much more durable as well, I've yet to break one, and my other cars are all LOW, much lower than cars ive seen on these boards) |
(Post 1421408)
that sucker is really ON THERE. in the following photo example, the 3 middle pieces (any pry tool, or even a flat head should work) all work fine and makes for effortless removal
https://cimg1.ibsrv.net/gimg/www.fit...948f3ea5ed.jpg |
I use the same alternative as I've got hoards of them from my past e36's. The Honda twist type just come off WAY too easy and often,
*You can use an old fork too, so you don't really need a trim tool (unless you have them already, or need them for other things too).
I would stray away from flathead screwdrivers for those, as they chew up the head too much |
Hi all,
sorry for jumping in, but is there any link to the suggested clips? Thanks a lot |
