My CVT on Steroids Dragracing
Old 03-11-2016, 10:18 PM
Myxalplyx's Avatar
Video from tonight (3-11-16). The wife only recorded the first two runs. She missed the 3rd run. Sorry for video quality.
Time of each run is in the video description.
This is my first time hearing what it sounds like from outside of the car.
Damn bumble bee!
Take note of the 60ft times. Not bad for a 130hp automatic CVT on skinny street tires. Hehe!
Went out to test some recent changes to the car. It's running good. Got lots more work to do though. Really need to get this thing fully tuned.
2015 Honda Fit LX CVT
I want to thank Ktuner for helping it to run like it is....consistantly low 15's. Gotta inch into the 14's in the 1/4 mile though.
Completely stock, I was running [email protected]
Old 03-11-2016, 10:24 PM
Well damn that cvt is consistent... !!
Old 03-12-2016, 10:31 AM
Very consistent!
Old 03-12-2016, 10:44 AM
Myxalplyx's Avatar
I had the loud 2" J's Racing 50R muffler changed out this morning and went back to the track for more testing. Notice something 'weird' in my Torque logs with the runs posted above. Even with the larger, much, Much quieter 2" Max Flo Pro muffler with crush bent piping, my times where similar this morning. Even a couple of quicker runs. Outside temperature was not that much different.
Even was getting 46mpg on the way home. Yes!
Perhaps I should update my sig with the new, slightly better 1/4 mile time. I have cams but I have not been able to bump up the rpm band to take advantage of them. This is still basically only an homemade intake, exhaust and lightweight pulley setup. No forced induction!
Just to put things into perspective, I want to post some 1/4 mile times from car magazines of some notable stock vehicles.
2016 Honda Civic Turbo - [email protected] (Motorweek)
2016 Honda Civic Turbo - [email protected] Car and Driver
2014 Ford Fiesta ST (turbo) [email protected]
2014 Fiat 500 Abarth (Turbo) [email protected]
2014 Mini Cooper S Hardtop (turbo) [email protected]
Car and Driver
Also, I took the average 1/8th mile time (9.955) and average 1/8th mile trap speed (72.5) and plugged them into a calculator to get what my 0-60mph times are.
I'm averaging 0-60mph of 6.82. Not bad at all for a 130hp naturally aspirated CVT econobox. 0-60mph Calculator
Old 03-15-2016, 10:55 PM
MyFirstHonda's Avatar
I can't view the video. It's marked as private.
Old 03-15-2016, 11:28 PM
Myxalplyx's Avatar
Sorry! Not sure what happened. Try now!
Old 03-16-2016, 06:52 AM
Good deal. The link works now.
Old 03-16-2016, 06:20 PM
ROTTBOY's Avatar
Location: Hawaii: relocated to Western Canada Sept, 2015
Looks like the wife is getting pretty fast. What was the other car in the second video? A GE Fit? Looking forward to future videos.
Old 03-16-2016, 06:24 PM
Myxalplyx's Avatar
I had to change the first sentence (Thanks). It may have been misleading. My wife was actually recording the videos. She don't want to race yet. I'd love for her to drive but she wouldn't know how to manipulate the CVT to get it in the high rpm quick enough.
Not sure what the other vehicle was. Can't remember!
Old 03-19-2016, 09:21 PM
That is so cool. It sounds incredible man haha. Would love to see more
Old 04-08-2016, 09:08 PM
Myxalplyx's Avatar
Tested some minor changes to try to make the car breathe a little more. 1/4 mile time barely better but trap speed has increased. So far so good.
Old 04-10-2016, 10:49 PM
jhn
jhn is offline
Have you tested the stock airbox but with just the intake splash piece removed behind the grille? It seems like its purpose is to prevent ingesting water, but at the cost of airflow.
Also, do you know to what extent the ECU adjusts for any increase in airflow?
I'm wondering if there might be a benefit to keep OE airbox right up to run time, then switch to your custom intake so the ECU can't adjust in time.
Also also, how hot are you getting the engine before your run? I noticed heat soak robs this little car of power.
I want to change my intake but only with some pretty objective data backing it.
The stock airbox already is a cold air intake that draws from a high pressure zone at the front of the radiator. I suspect it's going to be tough to improve on with this little NA engine.
Old 04-11-2016, 09:30 AM
Myxalplyx's Avatar
Yes! Back on 8-28-2014 I did some testing after looking at it.
Great Intake Test Post #12. Unfortunately, all my pics are gone (Imageshack). I did not notice much of a change in 1/4 mile times with the removal of this piece.
I can't say to what extent but I noticed while my maf g/s increased, the car managed to keep the same air/fuel ratios for the most part (12.0:1 - 12.2:1 air/fuel ratio). It had no problem adjusting and I never ran lean.
It would benefit if your custom intake has more heat soak than the stock one.
Instead of taking my word, I encourage anyone to take readings of their stock airbox temperature vs outside air temperature. There are two things working against the stock stetup.
1) The throttle body coolant that is going through the throttle body. If you watch your air inlet temps, you'll notice it keep going up by 2F everytime that coolant pumps through the throttle body.
2) The EGR piping that recirculates exhaust gas back into the intake. Mine is disconnected (Not condoned or encouraged). This pipe pumps hot exhaust gas back into your intake.
Currently the coolant is not bypassing the throttle body as we had a cold winter. Having the throttle body freeze in the open position wouldn't be fun. I've done everything I could to prevent heat soak in my homemade intake setups but it still gets it but it is much less than stock heat soak. It's a short ram setup that I've modified countless times to get it where I wanted it. I made a video of an older version of it because there were folks on here that stated you can not make your inlet air temperature the same as outlet air temperature. Here is a video to prove otherwise --->
Good luck on your journey!
Old 04-11-2016, 12:55 PM
jhn
jhn is offline
2015 Honda Fit LX CVT Acceleration 60-80mph and Intake Air Temp Test - YouTube
Thanks for the quick response.
At this point, I'm not looking to invest the time and money into experimenting; there's bigger rewards in suspension for the type of driving I like. I just want bolt-on instant gratification :-).
Much of the tests I see have too many variables in the control to isolate any objective performance gains. If the firewall area has a higher pressure zone relative to the OE zone in front of the radiator, then I see potential.
I'm watching this for sure.
Old 05-15-2018, 06:48 PM
evilchargerfan's Avatar
youve ran so many setups.... its hard to keep up with... lol
which setup was the one that netted 46 mpg?
Old 05-17-2018, 07:07 PM
Myxalplyx's Avatar
Nice to meet you Evil! General setup was using a cone intake (CAI short ram) with free flowing cat converter and aftermarket muffler. This wasn't the only time I noticed the gas mileage went up though but I wanted to point it out since I was running these times.
Honestly though, completely stock you could probably achieve those type of numbers. Better even! I remember it saying 51mpg when I first got my Fit and drove it from North New Jersey to Delaware. Very, very light foot driving it on the NJ Turnpike.
Old 05-19-2018, 12:48 AM
MysTiC27's Avatar
Excellent! The sound is very good from the Fit.
My 2015 EX-L Navi was manual, now I have the 2017 EX CVT Fit.
I really like the CVT. Only three days that I have my Fit 2017.
Congratulations for your performance.
Yvan
Hondarian
02-13-2017 07:32 PM
victorgarage
05-27-2014 03:44 PM
sanosuque
01-26-2008 03:23 PM
epin
11-19-2007 06:13 PM
Quick Reply: My CVT on Steroids Dragracing
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
