DannyJ7's Foxy Build
Old 04-26-2017, 08:51 AM
2Rismo2's Avatar
Originally Posted by Nedpoins
Does the Secret Weapon R Secret Weapon intake fit on a 2015 Fit with CVT?
Pretty sure it does. Stembridge had one on his.
  #62
Old 05-11-2017, 09:37 AM
DannyJ7's Avatar
FINALLY!!!!
  #63
Old 05-11-2017, 11:21 AM
mizike's Avatar
That is SICK!!! Two thumbs up!
  #64
Old 05-11-2017, 12:57 PM
2Rismo2's Avatar
You back stateside?
  #65
Old 05-12-2017, 03:28 PM
DannyJ7's Avatar
Originally Posted by 2Rismo2
You back stateside?
yep. Got back last Monday. Good to be home.
  #66
Old 05-23-2017, 08:24 PM
DannyJ7's Avatar
Turbo
be interested to see if this pans out.
  #67
Old 05-26-2017, 08:32 AM
2Rismo2's Avatar
There was some discussion on this thread with the same video: https://www.fitfreak.net/forums/3rd-...1-5t-swap.html
Now that you're home, let the mods proceed!
  #68
Old 06-03-2017, 01:37 PM
DannyJ7's Avatar
Just ordered a TS-WH500A for some bass. Updates once it's installed.
Update: got it installed by Geek Squad. Perfect amount of bass for a car this size. $270 including installation. Would do this again. Have it right under the driver's seat so it's not visible or in the way.
  #69
Old 06-19-2017, 09:45 PM
DannyJ7's Avatar
Rims inbound!!!!!!!!!!!!!!!!!!!!!!
Konig backbone 16x7 4x100 40 offset
  #70
Old 06-22-2017, 08:45 AM
DannyJ7's Avatar
Tires inbound.
BFGoodrich g-Force COMP-2 A/S
205 /50 R16 87W SL BSW
  #71
Old 06-25-2017, 11:56 AM
DannyJ7's Avatar
So everything came together today. Initial impressions are amazing. The difference that 7lbs a wheel and some better tires make is amazing. All in ~$800 on wheels and tires. I would do it again in a minute. Should have been the first mod I did!
Note: had to take of the spacers in the back. Was getting some nasty rubbing.
  #72
Old 06-30-2017, 12:14 AM
Jack Hammer's Avatar
Rims and tires look good.
  #73
Old 09-14-2017, 02:43 PM
DannyJ7's Avatar
So catch up...
The sub is the perfect size for this platform. Any more would be too much.
Just put in the acuity bushings. Good feedback...$75 though? Not sure I'd do it again...time will tell.
  #74
Old 09-22-2017, 11:26 PM
DannyJ7's Avatar
So took the hood crap off a while back. Not a bad experiment for $17. Looked too ricey.
  #75
Old 09-23-2017, 01:36 AM
Where did you install your sub?
  #76
Old 09-24-2017, 10:05 AM
DannyJ7's Avatar
Had Geek Squad (electrical is one of the few things I won't mess with) put it under the driver's seat. Works/sounds just right.
  #77
Old 10-05-2017, 12:46 AM
[LegenD]'s Avatar
Looks really great! Glad you took the wrap off haha
  #78
Old 10-26-2017, 12:28 AM
DannyJ7's Avatar
Thanks! The wrap was more an experiment than anything. Happy she's back to classy.
  #79
Old 11-15-2017, 10:57 PM
DannyJ7's Avatar
Foxy's been kinda waiting for upgrades while I transition from the military world to a civilian job. She's far from done!
  #80
Old 04-06-2018, 09:25 AM
DannyJ7's Avatar
Put on Moog Problem Solver sway bar links up front. Old ones were thin, rusting, and horrible. If you've got clunks up front, it's work trying. It fixed mine. Also, much easier to remove/install than the factory links.
Quick Reply: DannyJ7's Foxy Build
