3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Rear camber kit
Old Sep 24, 2019 | 12:32 PM
Fedfit's Avatar
Rear camber kit
Does any one know where or if there is a camber kit for a 2015 Honda Fit? Been looking but does not fit my year.
Old Sep 24, 2019 | 12:50 PM
Rob H's Avatar
You know it's an H-type torsion beam rear suspension? Like what you'd find in a Crossover SUV or minivan?
Old Sep 24, 2019 | 01:39 PM
hasdrubal's Avatar
Some people on the forum have done rear alignment with shims, which is way more work than I'd really want to take on. No idea if the shims allow enough adjustment to give any serious negative camber, but aside from trying to bend the arms on the rear beam (and that seems like a really bad idea) I don't think there's any other way to do it.
Old Sep 24, 2019 | 02:08 PM
USDM's Avatar
SPC offers the following shims (in a kit or sold individually):
https://www.heeltoeauto.com/suspensi...spc.71790.html
Old Sep 24, 2019 | 04:20 PM
evilchargerfan's Avatar
had the op just googled "2015 honda fit rear camber" , the same link USDM provided woulda been the 5th or 6th link down
I'll add details and pics, just in case the op is too lazy to click on Kevin's link
Details
Bring toe and camber back to factory specification on the rear of the Honda Fit with these fixed change shims from SPC. This 18 piece kit includes two each of a series of toe shims that will adjust from -0.5° to +0.5° in 1/10° increments and camber shims that will adjust from ±0.25° to ±1.0° in 1/4° increments. Combine up to two shims to dial in both toe and camber. Fix tire wear issues and return proper handling.
Set includes two each of the following (18 shims)
71791 / ±.10° Toe
71792 / ±.20° Toe
71793 / ±.30° Toe
71794 / ±.40° Toe
71795 / ±.50° Toe
71796 / ±.25° Camber
71797 / ±.50° Camber
71798 / ±.75° Camber
71799 / ±1.00° Camber
Installation time: .5 hr/side
Required: 1 - 2 shim per wheel (depending on desired change)
GE8_typeR
Jul 22, 2012 04:06 AM
ksgoon
Jun 10, 2010 11:35 PM
Jazz GD3
Jul 11, 2009 03:07 PM
HONDAJUNKIE
Nov 2, 2008 02:52 PM
mikow
May 12, 2008 03:26 PM
