3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Cheap Disc Brake Conversion??
Old Jun 3, 2024 | 02:34 PM
Kiju's Avatar
Question Cheap Disc Brake Conversion??
I need to preface by saying that I track the car and the specific event I'm joining has a 180 and a 360-degree turn and I want to add a dual caliper setup on the rear for the hydraulic handbrake. It's also hard to source some of the RS parts in Japan but mainly I want to try and find cheaper options ($1k more or less all parts disc conversion from the RS model)
I found out that the hub bearing assembly is identical to the drum and disc model (RS in Japan).
RS version | parts number: 42200-T5B-N51
However, the picture isn't the same as on the diagram but it matches the parts number.
Drum Brake Version | parts number: 42200-TY0-951
The only difference I can see in the picture is where the speed sensor mounts and If all are the same, I think it might work almost plug-and-play without much modification.
Here are the parts I think needed in this conversion:
1. Caliper Bracket/Adapter | parts number: 43250-T5B-950 | 35$/ea Honda
2. Caliper | parts number (R,L): 43018-T5B-000, 43019-T5B-000 | 150$/ea Honda
3. Pads | parts number: 43022-SAA-J50 | 100$/set Honda
4. Rotor | parts number: 42510-T5B-950 | 50$/ea Honda
5. Splash Guard
| parts number (R,L): 43254-T5B-950, 43253-T5B-950 | 18$/ea Honda
6. Handbrake Cable | parts number (R,L): 47510-T5B-952, 47560-T5B-952 | 38$/ea Honda
-The hub which I mentioned above if works will save 250$/set.
Total around 680$ w/o the hub
Questions are:
1. If the hubs are identical?
2. What alternatives can I use instead of the 7CLP13S Caliper from the RS?
3. 7CLP13S Caliper Bolt distance? Are all 7CLP13S the same even from the Civic and Integras?
THanks!!
Old Mar 19, 2025 | 01:15 PM
Not Haruguchi's Avatar
Camber plates
Just something to add you can likely go straight to a rear camber plate setup instead of buying the oem rear brackets. Cusco and spoon make them off the top of my head.
Old Jul 8, 2025 | 11:05 PM
gk5waffles's Avatar
Rear Disc Conversion
@Kiju
How many adapter/brackets did you buy?
43250-T5B-950? Are they interchangeable for Left and Right rear disc conversion?
Are all the parts listed everything I need for the conversion? Did you encounter any additional parts needed like bolts or shims?
Thank you!
Rfitfit
Jul 23, 2023 12:27 AM
GK5 Sport
Oct 17, 2022 05:19 PM
Suetjesz
May 15, 2014 01:43 PM
teamkitty
Sep 4, 2013 02:38 AM
GD3 IS GO!
Sep 2, 2008 04:47 AM
